Everything posted by VAXXi
Deduc targetul: femeia care n-are treaba cu masinile, si are bani suficienti ca sa-si petreaca marea majoritate a zilei prin magazine ce naiba e aia "automatic illumination of hazard warning lights" ? se pun automat avariile cand opresti neregulamentar ?
Indicator, martor sau sonda de Benzina
VAXXi replied to expero 16V's topic in Probleme tehnice Cielo, Nubira, Espero, Leganza
Daca ti-ai completa si profilul ... ca sa stim despre ce masina e vorba ... -
Jante Nubira II
VAXXi replied to Sharpe's topic in Modificări și tuning Cielo, Nubira, Espero, Leganza
Fals. Politia iti poate retine la control talonul daca dimensiunea anvelopelor si jantelor nu corespunde cu ceea ce ai in talon. De asemenea, la inspectia periodica nu primesti ok-ul tot din cauza asta. Ontopic: frumos profil au, arata bine. -
http://it.slashdot.org/article.pl?sid=05/07/15/155216 Duma zilei: Engadget has an interesting article regarding a new feature in Longhorn entitled PVP-OPM (Protected Video Path - Output Protection Management) which detects the capabilities of the display devices you are using and manages how (and if at all) content is sent to it. In short, this means that if Longhorn detects that your monitor is not "secure" enough, then your premium video content won't play on it until you buy one that is. Who gets to decide? The content providers of course." From the article: "So what will happen when you try to play premium content on your incompatible monitor? If you're "lucky", the content will go through a resolution constrictor. The purpose of this constrictor is to down-sample high-resolution content to below a certain number of pixels. The newly down-sampled content is then blown back up to match the resolution of your monitor. This is much like when you shrink a JPEG and then zoom into it. Much of the clarity is lost. The result is a picture far fuzzier than it need be." deci, daca n-ai monitor "autorizat", nu poti sa vezi filmu' !
Huse Scaune Cielo
VAXXi replied to mikken's topic in Modificări și tuning Cielo, Nubira, Espero, Leganza
Poate te-ajuta asta: http://www.daewooclub.ro/forum/index.php?showtopic=2528 ? -
Un caine la iesirea din Sinaia, luat central, sub scut; cainele mort, nici o paguba la masina. Un caine la ... nu mai stiu, tot intr-o plimbare; cainele scapat, dar schiopata; luat cu dreapta-fata, proiector spart, bara crapata. O pasare, la mare, in parbriz - norocul a fost c-a lovit in bratul stergatorului, nu in geam; pasarea ... a scapat, cred; pagube zero.
Mini, mini, da' astea sunt viitorul cand n-o sa mai fie loc in orase.
Se da urmatoarea problema: avem un adaptor la 12V, care atunci cand e bagat in priza face arc electric (in termeni populari, "flama"). Adaptorul are 2 posibilitati de bagare in priza: fara impamantare (cu cei 2 craci traditionali) sau cu un "adaptor la adaptor", adica un cablu de prelungire, care are si impamantare. Indiferent in ce tip de priza il folosesc, cu impamantare sau fara, cu prelungire sau fara, dracia face "flama". E singurul adaptor care face asa, altele nu se manifesta asa. Solutia momentan utilizata a fost sa bag intai adaptorul intr-un triplu-stecher, dupa care sa bag triplu-stecherul in priza de perete, si asa nu mai face. Care e problema ? e defect de fabricatie sau altceva ? sau ... "asa face toate" (eventual) ?
Ajutor Pt. Depistarea Tipului Unei Alarme
VAXXi replied to D.C.L.'s topic in Electronică și software auto
Chestia asta e (de obicei) parametru programabil, si se poate modifica cu ajutorul butonului "valet". Trebuie sa afli intai unde e butonul asta, dupa care sa faci rost de un manual de instalare pentru modelul respectiv ca sa afli procedura exacta (cam greu chestia asta, mai ales daca nu stii modelul exact). -
accize, vama, tva, adaos comercial ...
Da, cum ar veni iti dau un milion de lei pe aparatul vechi, bani care se scad din pretul unuia nou. Evident ca e o manevra imensa, daca de exemplu modelul HP Photosmart R717 costa la ei 13.999.900 (deci 14 milioane), si la http://www.cameredigitale.ro (nu e reclama, e doar un exemplu) costa 9.432.000 ... e clar, da ?
dreamweaver. s-ar putea sa te chinui nitel cu el la inceput, e 30 de zile trial dar scapi de toate imitatiile ieftine. in nici un caz frontpage
Pentru cei carora le plac(eau) questurile (pentru ca n-am mai vazut un quest bun de muulta vreme ): http://zahei.ines.ro/chasm.html
Vezi la "Optiunile mele", Board Settings: optiunea You may adjust the base time zone. Trebuie sa fie pe GMT +2h.
Contributia la un forum nu se masoara doar in numarul de posturi, domnule tico_rs ! Afla de la mine ca multe forumuri romanesti sunt infiintate si intretinute de oameni care nu au postat de 100 de ori pe forumul lor; asta inseamna ca nu au contribuit la el ? Replica mea se refera la faptul ca niste oameni civilizati nu s-ar comporta in modul in care s-au comportat cei din cauza celor carora a fost deschis acest topic ! Iar despre recomandarea dumitale, multumesc, am deja una si imi place. Ca sa spun asa: cat forumul a avut 100-200 de utilizatori, n-au existat probleme d-astea. E normal ca la 1000+ de membri, din care 50-100 vin la intalniri, sa existe amanunte care nu plac/nu convin unuia sau altuia. In mod normal, unor oameni civilizati nu trebuie sa le spui de doua ori un lucru, si nici sa discuti cu ei in contradictoriu. Daca inteleg, judeca prin prisma proprie si aleg: e corect, atunci se conformeaza; e incorect, atunci renunta elegant si asta e. Ei bine, romanul alege optiunea "nu fac nici asa, nici asa, hai sa m-apuc sa fac scandal ca e fun".
Corect. Unde's oamenii aia civilizati, ca nu-i vad ? Mai oameni buni, citesc si ma mir. Tot n-am inteles de fapt care e nemultumirea ? ca unii participanti la intalnire au fost trasi de maneca de catre cei care se ocupa de forum ? pai daca ei n-o fac, cine s-o faca atunci ? Intalnirea din parcare este organizata pentru forumul _asta_ , pe barba unor oameni care si-au pus _obrazul_ in joc, si facilitata de munca _altor oameni_ care pentru ca probabil li s-a urat cu prea mult bine, au decis ca "hai sa facem garagata", ca doar e gratuit si "ne mai radem si noi". Ei bine, aflati voi ca toti cei care pun umarul la forum o fac _moca_, isi rup din timpul lor _liber_ pentru a se ocupa de "pune invision, strange banii, ocupa-te de autocolante" si altele, si multumirea la chestia asta vad ca este "ba da' voi sunteti prosti rau, ce p00la mea va credeti voi de indrazniti sa imi ziceti MIE sa nu fac aia sau sa fac ailalta ?" Hai sa subliniez niste chestii: nu va place cum e organizat forumul, NU MAI INTRATI. DaewooClub2.ro este liber, daca voi credeti de cuviinta ca va descurcati mai bine cu intretinerea lui, faceti-o ! Nu va place cum si unde e organizata intalnirea ? NU MAI VENITI. Faceti-va alta intalnire, in alt loc, unde puteti face CE CREDETI VOI ! Noi asa ne pricepem sa facem lucrurile, asta e; sugestii acceptam, dar injuraturi pentru o munca prestata gratuit, nu !
Macar cerea pentru cafea, si nu pentru shlibovitza !
De pe topicul "Bula daciotului". Spicuim replici ale membrilor: * La mine la bloc sunt cateva loganuri, asa ca, eu perspicace asa cum sunt de felul meu, parchez intotdeauna intre doua dintre susnumitele masini. De ce? Simplu, tot praful se aduna pe loganuri si masina mea e giugiuc nu alta! * Eu am observat ca motorul de LGN se prafuieste mai repede. * in Dacia Logan, mupetii aia au o inertie mai mare decat in alte masini * MPI=motor pe injectie * Logan 1.6 de culoare alba (am auzit ca la culorile metalizate consuma mai mult ca au metal in ele) * am si eu o iintrebare : Pot sa pun planetare lungi pe o dacia ca sa fie mai lata ? * Cumpar breloc cu telecomanda alarma... de fapt nu e pentru mine. M-a rugat un prieten sa postez anuntul pentru el. Nu trebuie sa mearga sau ceva de genul asta. e numai pentru fitze. Cu cat e mai fitos cu atat ofera mai mult pe el. Poate aveti ceva cu leduri etc. Astept oferte! * Daca as putea sa-mi fac niste piese (pedalier, praguri) din aluminiu, cum credeti ca ar putea fi prinse? Prinderea in pocnituri este eficienta? Daca da, se umplu spatiile cu silicon? Exista si alte sisteme de prindere (sudura?) * Este normal ca atunci cand te urci in masina sa apara ceva mici trosnituri pe spate?De la ce ar fi? * Acu vreo 2 zile m-am dus si eu cu Loganul cel nou sa alimentez la OMV ca am auzit ca e buna. M-am invartit pe acolo, la pompa aveau 95 fara pb si 95 premium cu nu stiu ce aditivi smecheri. Acu eu am gandit cu cat mai scumpa cu atat mai bine si am bagat vreo 12 l de aia premium dar m-am chinuit ca nu prea intra nici pistolul (era un plastic ceva la intrarea in rezervor) si tot scapa manerul. Stiam ca trebuie fara plumb dar nu mi-am imaginat ca premium o fi cu pb. * Ce jenti de 17' cu tot cu cauciucuri s-ar potrivi la Logan... * La nova nu e valabila chestia cu o chestie (nu stiu cum ii zice) la cheder? * Chestia cu "invatarea" masinii nu stiu cum se face. Intai doar stropeste. * a vazut cineva ochelari pt faruri ? a-si fi interesat dar nu gasesc pe nicaieri. am vazut pt toate seriile de bmw audi etc. dar pt logan ... pauza * am si eu o mare nedumerire. daca m-ati putea juta ar fi super. vreau sa imi iau o lada frigorifica care se poate baga in priza. Este o priza sau ceva aceeasi functionalitate in logan. stiu ca in dacia 1310 nu exista asa ceva. Va multumesc anticipat.
http://www.evz.ro/eveniment/?news_id=190883 La ora actuala, ?nu exista nici o autoritate de reglementare?, dupa cum afirma un reprezentant al Asociatiei Societatilor de Leasing din Romania (ASLR). ?Aceste societati de leasing se constituie ca orice SRL sau SA , potrivit Legii 31, dar ele functioneaza fara a avea o autoritate deasupra, care sa le controleze. Exista doar un cod deontologic?, a mai spus reprezentantul ASLR. aveti grija cu cine faceti biznisuri.
realitatea tv. un complex comercial din budapesta a fost evacuat dupa o amenintare cu bomba. pretul petrolului a scazut, cotele la bursa scad (si continua sa scada). lira sterlina a scazut.
update tv: cladirea parlamentului polonez e in flacari, si este evacuata.
Large numbers of casualties have been reported after at least six explosions on the Underground network and a double-decker bus in London. http://news.bbc.co.uk/1/hi/uk/4659093.stm http://edition.cnn.com/2005/WORLD/europe/0...tube/index.html
mai ieftine, de la first bike. dar nu iti recomand, decat daca esti masochist (povestea unul pe softpedia cum mai mult a incarcat/descarcat scula din masina, ducand-o la service, decat sa pedaleze pe ea).
Aceeasi discutie pe forumul Motociclism.
Birourile sigilate, patronii de negasit.
