Geo_ZGA Posted July 10, 2017 Author Share Posted July 10, 2017 Dupa 11 ani, a venit vremea hidraulicii ambreiajului... sambata a facut figuri pedala, tinea fff sus, era elastica... am presupus ca e ba pompa, ba cilindrul, ba placa de presiune, desi intra bine in viteze. Azi am scos lichidul vechi negru, am inlocuit furtunul vas-pompa care facea probleme (crapat rau de tot), am bagat spray de frane pe instalatie si lichid nou de frana (aproape 0,5l) pana a iesit curat, tras cu pompa de vacuum. Link to comment
Corneda Posted July 11, 2017 Share Posted July 11, 2017 E prima schimbare de lichid la ambreiaj? Link to comment
Geo_ZGA Posted July 11, 2017 Author Share Posted July 11, 2017 Da, spre rusinea mea... de cativa ani tot ziceam ca-l schimb si mereu uitam. Sper ca am rezolvat problema, cel putin momentan. Link to comment
Geo_ZGA Posted July 13, 2017 Author Share Posted July 13, 2017 Azi, impreuna cu Dj-ul, am reusit sa schimb tamponul rupt. Si senzorul de mers inapoi de pe cutie (iar, sper sa tina mai mult asta). Link to comment
mirceajo Posted July 14, 2017 Share Posted July 14, 2017 (edited) Pe mine nu ma pui la socoteala?? ce om ) Edited July 14, 2017 by mirceajo Link to comment
TanoG Posted July 14, 2017 Share Posted July 14, 2017 (edited) Salut Geo, E greu de schimbat tamponul? Poti detalia pasii urmati? Multumesc Edited July 14, 2017 by TanoG Link to comment
Viktor Posted July 14, 2017 Share Posted July 14, 2017 (edited) 1. - dai scutul dreapta jos ori, pui un adaos din lemn intre baie si scut incit sa inchida golul ala. 2. - cu ajutorul unei tubulare de 17 mm (cred) urmat de adaptor cardanic si prelungitor (chiar doua pentru a lucra mai comod) slabesti cele doua suruburi din lateral, slabite doar. 3. - slabesti/desfaci cele doua piulite de sus intr-atit incit piulitele sa nu iasa de pe filet (~1cm, sau mai mult, in functie de cit permite cele doua suruburi pe care-s piulitele) iar motorul se lasa. 4. - introduci cricul (plus o bucata de lemn pe cric pentru a nu deteriora scutul) sub baie o idee catre in fata (mai pe coltu baii asa zis) sa preia greutatea pe latura respectiva si ridici motorul cu ajutorul cricului nici mai mult nici mai putin decit ii necesar, adica, cit sa fie preluata greutatea motorului de pe cele doua piulite . 5. - dai cele doua piulite afara dupa care cele doua suruburi din lateral si cade tamponul. Rog sa fiu corectat unde am gafat. (la diametru' cheii ? ) Edited July 14, 2017 by Viktor Link to comment
Dj_Dark Posted July 14, 2017 Share Posted July 14, 2017 Adaugiri, trebuie data cureaua de AC jos, altfel nu iese. Dupa desfacere trebuie coborat motorul sa faci loc sa iasa pe jos. Alternativ desfaci suportul de pe blocul motor, eu am preferat prima varianta din cauza unui furtun de servo care trece fix prin fata unui surub. Cheie de 17 la alea mari si 14 (sau 15) la alea din lateral. Link to comment
Viktor Posted July 14, 2017 Share Posted July 14, 2017 (edited) Imi scapara din vizor AC-ul, probabil unde nu il am. Unde nu e AC, cade tamponul din cite retin (mestereala de nu mai retin citi ani in urma .. ). Altfel, suficient de simpla interventia. Cel putin eu astfel o vad. Edited July 14, 2017 by Viktor Link to comment
Geo_ZGA Posted July 14, 2017 Author Share Posted July 14, 2017 Hai ca au raspuns deja colegii Nu e mare inginerie, dar e spatiul mic si te forteaza la diverse manevre. Mircea, tu nici moral nu ne-ai sustinut de data asta ) Lasa ca te revansezi cu plansa de bord, dupa concediu Link to comment
Geo_ZGA Posted December 21, 2017 Author Share Posted December 21, 2017 Mai dau si eu praful de pe topic... toata vara, masina a vazut doar benzina si cheie. Si multa hinghereala, drumuri nasoale, noroaie, pietre etc. Cum nici o minune nu tine 100 ani, acum 2 saptamani (dupa o noroiala grava), m-am intors Cta-Buc cu aproape un plin de benzina, peste 15% consum... plus pierderi de putere pe la 4000 ture. Proiectoarele ardeau siguranta mereu, acum o saptamana nu s-au mai aprins nici farurile... pe astea le-am rezolvat in seara respectiva, siguranta noua, releu nou, blocul curatat si gresat. Azi am facut plinul la antigel (pierdea pe la un colier, vad ca nu mai pierde momentan), am schimbat bujiile vechi NGK Iridium, uzate, cu cele originale Champion (cu care a venit masina din fabrica), s-a rupt o fisa dar am reparat-o, am rezolvat si proiectoarele (un fir din proiector avea izolatia tocita si dadea la masa), am curatat si iac-ul cu ocazia asta... si filtrul de aer curatat si uns saptamana trecuta. Acum mai trebuie sa completez putin ulei si sper sa ma mai duca pana la primavara fara probleme. Sper sa reusesc in ianuarie sa o si ridic din suspensie... Link to comment
Horica00 Posted January 3, 2018 Share Posted January 3, 2018 Urmarind topicul,am vazut ca a suferit reparatii asemanatoare cu cele facute la a mea.Intrebare,dupa doi ani de zile,mai sunt problem cu rugina?Mie mi se spune ca dupa maxim 2-3 ani,rugina este la loc,ceea ce nu este prea multumitor,avand in vedere ca am cheltuit o carca de bani pe tablaraie...... Link to comment
Geo_ZGA Posted January 3, 2018 Author Share Posted January 3, 2018 Aripa stanga spate, care a fost peticita, e mai rau ca inainte. Pe dreapta spate a aparut iar. Plus prin alte locuri pe unde nu avea inainte... si totul din primul an. Usile vad ca au rezistat, cu vaselina bagata in ele. Nici pragurile nu arata rau, dar mi-a fost frica sa ma uit f atent ) Link to comment
Salex Posted January 4, 2018 Share Posted January 4, 2018 O dam in offtopic. Va rog sa mutati discutia pe topicul dedicat, chiar daca Geo a fost amabil si a raspuns pe topicul dedicat masinii sale . Link to comment
Geo_ZGA Posted February 4, 2018 Author Share Posted February 4, 2018 Am zis sa mai bag si Cielo in seama, dupa ce m-a "tras de maneca"... pompa de ambreiaj schimbata iar, cea luata de la Mircea a cedat. Am pus Valeo noua, cu mici probleme ca nu se desfacea conducta... lichid nou, aerisire si aia e. Link to comment
Geo_ZGA Posted March 18, 2018 Author Share Posted March 18, 2018 Azi i-am facut schimbul de ulei si am completat si uleiul la cutie (acum 1 an am pierdut ceva ulei cand am scos planetara). Ambele Motul, 5w40 si 75w90. Cu injuraturile de rigoare, pt ca la ultimul schimb de ulei m-am dus la un service de cartier (lene si fara chef sa ma murdaresc) si a strans ala filtrul de ulei in dusmanie. L-am scos cu surubelnita... In speranta cam strans totul cat trebuie, cel putin 1 an mai merge pe uleiul asta. Link to comment
KumKum Posted March 19, 2018 Share Posted March 19, 2018 Ce Motul ai bagat, x-cess ori x-clean? Se comporta ok la cald/rece? Link to comment
Geo_ZGA Posted March 19, 2018 Author Share Posted March 19, 2018 Xcess, il folosesc de cativa ani buni si sunt multumit de el. Nu tacane nimic, nu il consuma... nu am ce sa-i reprosez. Acelasi ulei l-am luat si pt "explorator" Link to comment
KumKum Posted March 24, 2018 Share Posted March 24, 2018 Am luat si eu 5w40 8100 x-cess, sa-l vad cum se comporta... Link to comment
mike.omega Posted March 24, 2018 Share Posted March 24, 2018 Eu folosesc uleiuri Motul la Citroen si sunt foarte bune. Pe diesel X Clean si pe benzina 6100 Synergie+. Cel putin in cazul motorului diesel am observat inca de la primul schimb o reducere a zgomotului Link to comment
Dj_Dark Posted March 24, 2018 Share Posted March 24, 2018 X-clean ala il foloseam si eu la espero mai demult, intr-adevar parea mai silentios motorul insa era destul de scump pentru jegul ala de motor si am zis la un moment dat ca nu mai merita. desi era de diesel mergea si la benzina perfect. Era peste x-cess parerea mea. Gata cu offtopicul 1 Link to comment
Geo_ZGA Posted March 31, 2018 Author Share Posted March 31, 2018 De voie, de nevoie, ieri seara am schimbat bujiile... am pus NGK bpr6e, 10 lei bucata. Simptome: mici intreruperi la ralanti sau mers constant, lipsa de putere, o cadere grava de putere pe la 4000 ture (nasoala in depasiri). Am avut noroc sa gasesc ieri seara magazin deschis, am imprumutat o cheie de bujii de la un vecin si aia a fost. Link to comment
Geo_ZGA Posted April 16, 2018 Author Share Posted April 16, 2018 Si ca sa inchei mini-vacanta cu brio, cand am iesit ieri de pe A2, masina a inceput sa vibreze urat, de parca eram pe pana. Rotile umflate, articulatiile ok, arcurile ok, totul bine la prima vedere. Am descoperit azi la vulcanizare: anvelopa stramba pe calea de rulare (aplatizata), probabil s-au rupt sarmele. Mi-a pus o anvelopa all season, i-o dau inapoi cand schimb anvelopele. De bine ce cautam anvelope noi... Link to comment
Geo_ZGA Posted April 19, 2018 Author Share Posted April 19, 2018 Azi am inceput revenirea spre stock... jantele pe 15 au ajuns la Dj-ul, iar filtru sport a fost inlocuit cu originalul (inca incomplet, urmeaza si tubulatura fata). Sunetul nu mai e asa frumos, dar... e mai simplu asa. Link to comment
Viktor Posted April 19, 2018 Share Posted April 19, 2018 Cum asa? O scoatem la licitatie ? Link to comment
