andreib Posted September 10, 2011 Share Posted September 10, 2011 (edited) @Danutz: placutele ieftine si cu insertii metalice. Cumpara alte placute ca si asa sunt f ieftine (40-50RON). @Gyk: discuri de frana ovalizate. Solutia: altele noi! Edited September 10, 2011 by andreib Link to comment
Danutz1987 Posted September 11, 2011 Share Posted September 11, 2011 Andrei,am TRW,data trecuta le-am tinut pana s-au uzat aproape de tot,poate al prins lot mai prost...Am pus si alt disc,aveam 2 pe care le-am cumparat pt cielo si nu se potrivesc...Ma gandeam sa schimb si discul+placutele de pe stanga pe dreapta sa vad pe care parte se aude apoi.Poate sa fie si rulmentul?Acum 3 zile am schimbat si capul de planetara,poate sa fie si de acolo? Link to comment
madalosu Posted September 11, 2011 Share Posted September 11, 2011 On 9/10/2011 at 5:10 PM, is 83 gyk said: salut am si o problema cu frana la nubira 2 2004 la viteze mai mari 90/120/h cand calc frana imi trepideaza volanul?? La mine a fost de la jante. Tot la fel trepida rau Link to comment
andreib Posted September 11, 2011 Share Posted September 11, 2011 Si nu vibra decat in franare? Link to comment
Danutz1987 Posted September 11, 2011 Share Posted September 11, 2011 Am schimbat discurile intre ele,am pus placutele cele vechi,la fel face !Cum verific rulmentul?Are 1 sau 2? Link to comment
Viktor Posted September 11, 2011 Share Posted September 11, 2011 On 9/10/2011 at 11:03 AM, Danutz1987 said: ...am pilit bavura de la extremetitatile discului ... Asta nu influenteaza cu nimic frinele, la tamburi se practica pilirea/slefuirea, pentru o usoara ansamblare cu sabotii apropiati. Din cite inteleg problema e la frinare, n-are legatura cu rulmentii, care "mirie" continu daca au defect. Link to comment
andreib Posted September 11, 2011 Share Posted September 11, 2011 Are 1 rulment. La mine unul haraia la viteza f mica dar doar cu masina pe roti, pe elevator era liniste perfecta. Link to comment
Danutz1987 Posted September 12, 2011 Share Posted September 12, 2011 Se aude acel zgomot si cand e curba la dreapta mai stransa si e pe coborare sau pe urcare,pe drum drept nu am auzit! @Victor,nu stiu ce ar putea fi la sistemul de franare atata timp cat am schimbat placutele si discurile intre ele si se aude pe aceeasi parte.Am verificat toate componentele etrierului si sunt ok.Poate totusi sa fie de la capul de planetara pe care l-am schimbat?Cateodata mi se pare ca inca il mai aud cum "cloncane"! Link to comment
andreib Posted September 12, 2011 Share Posted September 12, 2011 Schimba rulmentul, nu e atat de scump (intre 50 si 90 ron). Link to comment
Danutz1987 Posted September 12, 2011 Share Posted September 12, 2011 Ok...astazi il comand si diseara dau cu el sus Sper sa se rezolve ca e cea mai stresanta pb pe care am avut-o pana acum la masina! Link to comment
Viktor Posted September 12, 2011 Share Posted September 12, 2011 Eu ramin la capul de planetara, daca e schimbat recent cu unul SH. Cei drept si zgomotul unui rulment se accentuiaza pe curba, dar persista si pe drum drept. Link to comment
Danutz1987 Posted September 12, 2011 Share Posted September 12, 2011 Capul ce planetara a fost nou...si nu am prea ascultat pe drum drept,dar mi se pare ca se aude,dar f.f.f putin si doar la viteze de peste 70-80 km/h! Link to comment
korydon Posted September 12, 2011 Share Posted September 12, 2011 On 9/12/2011 at 10:43 AM, Danutz1987 said: se aude,dar f.f.f putin si doar la viteze de peste 70-80 km/h! Eu zic ca-i rulmentul. Link to comment
Danutz1987 Posted September 13, 2011 Share Posted September 13, 2011 Schimbat rulment,facea la fel...E un disc de cauciuc pe planetara,din cauza telescoapelor uzate,cand franam freca in ceva...El se auzea...Rulmentul oricum trebuia schimbat...Era destul de uzat!toata afacerea a costat 60 lei Link to comment
madalosu Posted September 20, 2011 Share Posted September 20, 2011 (edited) Salut. Am schimbat azi bieletele antiruliu la nubira 2 pe fata. Le mai schimbasem odata cam acum 1 an dar se pare ca au fost SRL-uri (nu am stiut) si ma tot vaitam eu aici pe forum de un bocanit pe spate, mi se parea. Tot zgomotul era de la bieletele antiruliu am pus originale acum(21 Ron una), nu se mai aude nimic acum nici pe fata nici pe spate. Nu-mi vine sa cred cat scandal faceau 2 rahaturi d-alea,s-a chinuit mecanicul o gramada sa le dea jos, erau foarte ruginite piulitele. Am schimbat si garnitura capac cubultori (45 Ron originala GM) acum sper sa numai piarda ulei, o sa vad la urmatorul schimb deocamdata in 7000 km facuti de la schimb e joja la semnul de minim. Alte nimicuri ce-am mai facut, am dat cu WD40 pe la mecanismele de la centura, schirtiiau cand le cuplam ziceai ca e de la scaun si am mai dat tot cu WD40 pe la aeroterma de la pasager si pe sus pe la ventilatiile pentru parbriz pentru ca tot scotea zgomote ciudate de acolo incontinuu in mers si era foarte enervant, chiar daca nu aveam pornite aerotermele, acum nu se mai aude nimic nici de acolo nici de la centuri. Face minuni WD40 asta. Scuza-ti pentru post-ul asa lung. O zi buna! Edited September 20, 2011 by madalosu Link to comment
daewoo Posted September 26, 2011 Share Posted September 26, 2011 (edited) Am vazut la Nubira 2 sub capacul negru de la motor cum se vede ulei mai mult uleioasa chiuloasa sau cum se numeste.Sa fie garnitura de chiuloasa? Daca ma uit sub masina nu se vede picaturi de ulei sa piarda.Ce anume ar putea sa fie? Edited September 26, 2011 by daewoo Link to comment
Salex Posted September 27, 2011 Share Posted September 27, 2011 On 9/26/2011 at 10:33 PM, daewoo said: Sa fie garnitura de chiuloasa? Nu, este doar garnitura capac culbutori. Link to comment
daewoo Posted September 27, 2011 Share Posted September 27, 2011 On 9/27/2011 at 6:28 AM, Salex said: Nu, este doar garnitura capac culbutori. Nu inteleg cum se prelinge.Recunosc ca la motor nu m-am mai uitat de mult timp.Stiu ca inainte sa merg la revizie era totul ok.Oare cel care a facut revizia sa fi fost mai putin profesionalist? Link to comment
scoopy Posted September 27, 2011 Share Posted September 27, 2011 Unde imi recomandati sa-mi schimb placutele de frana fata la Nubira II ? Credeti ca ar fi mai bine sa le cumpar separat si sa platesc doar manopera sau nu are rost sa ma complic si sa le cumpar direct de la service-ul care mi le schimba. Cel mai important factor in alegerea mea e pretul manoperei. Va multumesc! Link to comment
Juliaen Posted September 28, 2011 Share Posted September 28, 2011 On 9/27/2011 at 7:24 AM, daewoo said: Oare cel care a facut revizia sa fi fost mai putin profesionalist? Nu cred, mai ales fiind cunoscuta incidenta cazurilor de schimbare a garnituii culbutori la nubira; eu am schimbat prima pe la 25.000km iar a doua la 56.000. Nu e scump de schimbat, 150-200 Ron (neaparat cu capacele laterale) dar conteaza foarte mult ca cel ce o monteaza sa aiba mana buna. Succes! Link to comment
daewoo Posted September 28, 2011 Share Posted September 28, 2011 On 9/28/2011 at 8:29 AM, Juliaen said: Nu cred, mai ales fiind cunoscuta incidenta cazurilor de schimbare a garnituii culbutori la nubira; eu am schimbat prima pe la 25.000km iar a doua la 56.000. Nu e scump de schimbat, 150-200 Ron (neaparat cu capacele laterale) dar conteaza foarte mult ca cel ce o monteaza sa aiba mana buna. Succes! Mersi foarte foarte mult pt infomatii! Link to comment
Danutz1987 Posted September 29, 2011 Share Posted September 29, 2011 De cand am schimbat capul de planetara si bucsile de la brat,daca schimb vitezele la peste 3000 rpm, cand ajunge in treapta superioara imi trage masina brusc si mult dreapta,la fel se intampla si daca accelerez brusc si snt in treapta mica de viteza (2 sau 3)plus ca am pierdut si din stabilitate,daca iau ceva curba la dreapta scartaie cauciucul rau de tot,pana acum nu facea asa.Trebe sa ii fac geometria? Link to comment
andreib Posted September 29, 2011 Share Posted September 29, 2011 Probabil a fost facuta geomteria cu bucsile belite... Deci da, trebuie sa faci geometria . Link to comment
Danutz1987 Posted September 29, 2011 Share Posted September 29, 2011 Inca ceva...am cuplajul de la volan cam dus...e vreo sansa sa imi poata face geometria bine cu el asa? Link to comment
