buburuza vesela Posted June 17, 2015 Share Posted June 17, 2015 Tablita aia de pe spatele placutelor au rol de "radiator" pentru placute. Foarte adevarat ca se gasesc placute si fara. Dar cine se respecta si cunoaste(la producator fac referire) v-a pune acele "radiatoare" pe spatele placutelor. Pana la urma conteaza si cum iti vinzi marfa. Nu au rol antizgomot. Link to comment
calinjack Posted June 17, 2015 Share Posted June 17, 2015 Nu pot sa pricep ce rol de radiator au.sunt foarte subtiri. Link to comment
Salex Posted June 17, 2015 Share Posted June 17, 2015 (edited) Asta cu radiatorul este pe post de snoava ! Placuta aia subtire de pe spate are fix rol antivibratii ! Adaug faptul ca exista producatori care nu pun tabla ci un material cauciucat. LE: Ca sa nu pierdem timpul cu discutii ulterioare inutile, anexez niste linkuri: http://www.autoanything.com/brakes/61A7209A0A0.aspx http://www.napabrakes.ca/products/brake-pads-shoes/premium-pads/ https://data.epo.org/publication-server/rest/v1.0/publication-dates/19850424/patents/EP0138081NWA1/document.html (asta era suficient !) http://www.nucap.com/products/shims/nu-lok/ http://www.autobarn.net/monroe-brake-pads.html http://auto.howstuffworks.com/auto-parts/brakes/brake-parts/brake-shims.htm http://brakeperformance.com/brake-shims.php Edited June 17, 2015 by Salex Link to comment
azer Posted July 18, 2015 Share Posted July 18, 2015 Salutare. Am un matiz. Am schimbat sabotii spate stanga si dreapta. Frana spate stanga functioneaza. Dreapta spate nu. Am deafacut conducta si nu vine lichid de frana. Ce poate fi ? Prima oara am crezut ca e de vina pistonasul pentru ca a curs lichid cand apasam frana. Dupa ce am schimbat la pistonas cilindrii nu a mai functionat deloc. Intre timp am ramas fara lichid si am cumparat si am pus dar nu a mai venit lichid la roata( am desffacit conducta). Pedala de frana cand o apas nu se duce pana la fund. Link to comment
pernaku Posted July 18, 2015 Share Posted July 18, 2015 !. @calinjack; Am schimbat și eu plăcuțe frână așa cum le-am cumpărat de la distribuitorul local. Le-am schimbat au 32K Km ... fără nicio problemă ! Susțin cele afirmate de @salex 2.@azer; trebuie verificat traseul hidraulic de la pompă la cilindrul recepror ... să nu aibă o strangulare, sau ... ceva care să-i cauzeze lipsa debitului lichidului de frână la cilindrul receptor reclamat pentru nefuncționare. Și aerisirea circuitului hidraulic poate conduce la rezolvarea situației. Mult succes ! "> Link to comment
zztop Posted September 25, 2015 Share Posted September 25, 2015 Salutare tuturor Pe scurt problema care ma apasa.. Acum ceva timp am fost la service pentru a-mi inlocui una din tobe si rulmentii fata la Matiz. Treaba a fost facuta insa dupa ce am luat masina am observat un huruit la roata dreapta fata. M-am dus inapoi, mecanicul mi-a spus ca e de la placuta. M-am mirat stiind ca face asa cind ori placa ori placuta este noua si trebuie sa ia forma discului ca sa nu mai scoata acel zgomot. Mirarea mi-a fost mai mare deoarece nu s-a umblat decit la rulment. Mentionez ca atunci cind este in miscare, scoasa din viteza, nu se aude acel huruit insa cind frinez se aude mai tare functie de presiunea exercitata pe pedala de frina. De atunci am tot asteptat sa dispara sunetul acela insa dupa o luna face la fel daca nu mai tare. Intrebare: poate sa fi fost ceva montat gresit? sau prea strins? este cazul sa cumpar discul si placutele , sau poate pistonul nu lucreaza(din senin)? Ce ma sfatuiti? Multumesc PS. Caut un mecanic bun care se pricepe la Matiz ( mecanicul meu a plecat in Germania..definitiv ) Cesar Link to comment
danutza Posted October 1, 2015 Share Posted October 1, 2015 Verifica daca nu ai joc la roata respectiva. E posibil sa nu fi strans suficient piulita la planetara si sa faca rulmentii zgomot. Link to comment
buburuza vesela Posted October 1, 2015 Share Posted October 1, 2015 Problema a fost identificata: Trebuiesc schimbate discurile de frana, prin subtierea acestora, placutele ating de gradul rezultat in forma de "T". De aici si acele zgomote gen rulment defect. Link to comment
