emil_matiz Posted October 19, 2009 Share Posted October 19, 2009 Am inteles. O sa merg pe TOTAL, varianta recomandata de service 75W80 GL4. Merci mult! Link to comment
mitosu Posted October 20, 2009 Share Posted October 20, 2009 nu inteleg de ce unii recomanda gl4 si altii recomanda gl5,in special service-uri. Link to comment
emil_matiz Posted October 20, 2009 Share Posted October 20, 2009 On 10/20/2009 at 10:31 AM, mitosu said: nu inteleg de ce unii recomanda gl4 si altii recomanda gl5,in special service-uri. Depinde unde mergi. A mea e inca in garantie si merg la dealer. Ei mi-au recomandat 75W80 GL4 de la Total. Cert e ca eu personal nu am gasit nicaieri nici in cartea de service nici in manual ce tip de ulei recomanda producatorul. Link to comment
mitosu Posted October 20, 2009 Share Posted October 20, 2009 merg in service dedicat daewoo, deci nu la nea nicu din garajul de la coltul strazii, ei au si magazin de vanzare exclusiv daewoo,si nu cred ca au interes sa ma pacaleasca sunt client de mult timp la ei. Link to comment
tolin Posted October 20, 2009 Share Posted October 20, 2009 On 10/20/2009 at 10:34 AM, emil_matiz said: Cert e ca eu personal nu am gasit nicaieri nici in cartea de service nici in manual ce tip de ulei recomanda producatorul. Gasesti la Transmisie/Specificatii generale/ 5B-2, pag.639 din varianta pdf. On 10/20/2009 at 10:31 AM, mitosu said: nu inteleg de ce unii recomanda gl4 si altii recomanda gl5,in special service-uri. Unii citesc si altii nu citesc. Link to comment
emil_matiz Posted October 20, 2009 Share Posted October 20, 2009 Am gasit dupa ce am frunzarit bine manualul imprimat. Scrie SAE 75W85, dar nu spune nimic despre GL4 sau GL5. Link to comment
mitosu Posted October 21, 2009 Share Posted October 21, 2009 am fost azi in service si am schimbat una alta pe la matizache,si cu ocazia asta l-am intrebat pe meserias care este misterul uleiului pentru cutia de viteza adica gl4 sau gl5 ,eu banuiam ca asta e, si mi-a spus in felul urmator ca se foloseste gl4 sau gl5 in functie de cutia de viteze in special anul masini si tipul de motorizare mpi sau cea clasica cu carburator. Link to comment
lucius_1982 Posted October 21, 2009 Share Posted October 21, 2009 Schimba mecanicul ca e varza rau . Cum carburator la matiz?? Link to comment
mitosu Posted October 21, 2009 Share Posted October 21, 2009 pina in din 98 sau 99 pina in 2005 cand sa trecut pe ecu injectie ce crezi ca a fost? din 98 sau 99...am vrut sa spun. Link to comment
lucius_1982 Posted October 21, 2009 Share Posted October 21, 2009 (edited) Ia ghici!!! Din 98-2005 a fost injectie cu delcou (euro2) din 2005-2008 a fost injectie cu aprindere directa (euro3 si 4) deci carburator doar la tico gata cu fftopic: Edited October 21, 2009 by lucius_1982 Link to comment
tolin Posted October 21, 2009 Share Posted October 21, 2009 On 10/21/2009 at 10:48 AM, mitosu said: ... l-am intrebat pe meserias care este misterul uleiului pentru cutia de viteza adica gl4 sau gl5 ,eu banuiam ca asta e, si mi-a spus in felul urmator ca se foloseste gl4 sau gl5 in functie de cutia de viteze in special anul masini si tipul de motorizare mpi sau cea clasica cu carburator. Tipul uleiului la un mecanism se alege in functie de forma constructiva a angrenajelor, n-are vreo legatura cu ce se afla in exteriorul cutiei. 1 Link to comment
mitosu Posted October 21, 2009 Share Posted October 21, 2009 pai da la generatia de cutie asta era ideea ,acum fiecare cum stie. Link to comment
closchkutza Posted October 21, 2009 Share Posted October 21, 2009 Pe toate tipurile de matiz(E2, E3, E4) de la noi s-a montat acelasi tip de cutie, aceeasi generatie si anume prima, cea cu care a aparut matizul. Nu exista diferente intre ele. Mecanicul ala care a vazut Matiz cu carburatie este genial! Imi dau seama cate cunoaste despre masinile astea. Link to comment
adrianenache Posted October 26, 2009 Share Posted October 26, 2009 Salut la toata lumea, Am nevoie de un sfat. Am un matiz din 2003 56.000 km, cu carcasa cutiei de viteze sparta. Evident ca sa dus tot uleiul si acum trebuie pus altul (dupa ce reparam carcasa Ce model imi trebuie si cam cat costa? Si evident de unde il pot lua? La service mi s-a spus ceva de genul 240 da nu am inteles daca roni sau lei vechi. Va multumesc, Adrian Link to comment
niki Posted October 26, 2009 Share Posted October 26, 2009 (edited) Am luat hotararea sa schimb uleiul din cutie. Am tot cautat ulei SAE 75W85 dar e imposibil de gasit. Intamplator acum am gasit Ulei Tutela (2 tipuri)-pe net la capitolul service fiat Inainte de a suna la distribuitor si sa intreb daca au , va cer parerea. Exceptand ca este ulei Italian- recomandat de Fiat, Afla nu stiu nimic. Pretul am inteles ca ar fi pe la 6-7 E. Asta daca vand si la pers. fizice Am descarcat specificatiile tehnice pt cele 2 tipuri Are rost sa fac experiente sau sa merg pe total 75w80? 1474_ssic_ENG.pdfFetching info... 1474_stec_ENG.pdfFetching info... 1492_ssic_ENG.pdfFetching info... 1492_stec_ENG.pdfFetching info... Edited October 26, 2009 by niki 1 Link to comment
niki Posted October 27, 2009 Share Posted October 27, 2009 Am sunat la distribuitor Nu vand catre persoane fizice, dar daca se dau datele unei firme se face factura. Nu exista cantitate minima. Livreaza si prin curier. Pretul e undeva sub 6 E(fara TVA) Datele de contact: http://www.flromania.com/onas_kontakt_1.html Au sediul pe langa Agronomie si pe urma treb mers la depozit pe sos.Chitila. E ceva alergatura Poate ne strangem mai multi si ne bagam la o livrare prin curier(decat sa alergam prin Bucuresti) 1 Link to comment
closchkutza Posted October 27, 2009 Share Posted October 27, 2009 Nu e mai simplu sa iei Total 75w80? Link to comment
Gabiti Posted October 27, 2009 Share Posted October 27, 2009 On 10/19/2009 at 7:36 PM, emil_matiz said: Am cautat azi despre uleiul TOTAL pt cutia de Matiz dupa ce am vb la service si am gasit un topic. Acum nu mai dau de el nicicum. Cert e ca se vorbea despre uleiul pentru cutie la Matiz si Tico. Unii spuneau ca au bagat 75W80 in loc de ..W85 care nu se gaseste, altii ..W90. AM gasit si o parere a cuiva care spunea ca aditivii din noile uleiuri performante pot ataca bronzul si trebuie verificat daca in cutia de viteze de la matiz exista piese confectionate din bronz. Ce mi se pare ciudat e faptul ca uleiurile 75W80 GL4 Esso, Elf si TOTAL costa aproximativ 35 de ROn litrul iar Mobil 1 Mobilube 75W90 GL5 costa pana la 70 ROn litrul. De ce tocmai dublu? Ce minuni face? In cplus untii sustin pe forum ca un ulei ..W90 nu isi va atinge performantele in cutia de Matiz pentru ca nu e pt ea. Se gaseste ulei Castrol SMX-S 75W85 fie la UNIX , ori la Oradea fie in Ungaria. Daca nu au, se da comanda si in cateva ore il ai. Link to comment
niki Posted October 27, 2009 Share Posted October 27, 2009 On 10/27/2009 at 8:08 AM, Gabiti said: Se gaseste ulei Castrol SMX-S 75W85 fie la UNIX , ori la Oradea fie in Ungaria. Daca nu au, se da comanda si in cateva ore il ai. Multumesc Am sunat (au locatii si in bucuresti) http://www.unixauto.ro/UnixOnline/Unix_SzervizHalozat_Form.aspx 60 lei \litru. 1 Link to comment
emil_matiz Posted November 6, 2009 Share Posted November 6, 2009 Am facut schimbul de ulei in cutie de viteze. Am luat GM Manual Transmission fluid original de la Chevrolet. Deocamdata intra mia bine in viteze si nu mai aud zgomote. Totusi din cand in cand, cand bag a doua, si acum dupa schimbul de ulei aud un obstacol parca, undeva peste 20 km/h, dar doar uneori. Oare depinde de cat e de turat motorul in momentul schimbului de viteza? Link to comment
markus2007 Posted February 6, 2010 Share Posted February 6, 2010 Salutare la toata lumea! Sunt nou pe forum (ca scriere, ca de citit tot citesc de ceva timp) si as avea niste intrebari la care nu prea gasesc raspuns . Daca ma puteti ajuta sunt recunoscator. Sunt posesorul unui Spark(2008) si anul trecut a trebuit sa fac revizia de 1 an. Am sunat la radacini, am intrebat pretul ,.... am ramas cu gura cascata : 650 ron(6.500.000). Deci m-am hotarat sa schimb singur toate celea ce sunt cuprinse in carte. Toate bune pana la ULEIUL PT. CUTIE. In carte 75w-85. Am plecat in lui dar degeaba nici vorba de 75w-85. Pana la urma am achizitionat ulei TUTELA 75w-80 gl 5. Intrebarea mea este daca am vreo problema cu acest ulei, trebuie schimbat, nu este bun ??? Am vazut la cineva de pe forum foto cu ce baga cei de la service: ulei nemtesc dar fara nicio specificatie (75w-85, gl4, gl5 etc). Asa ca dupa citiri profunde inca nu sunt lamurit cu acest miraculos ulei pt. cutie. Mentionez ca iarna asta si la -22 grade cutia merge brici. Daca poate cineva sa ma lamureasca cum e cu vascozitatea, gl4, gl5... si poate un ulei compatibil Link to comment
Gabiti Posted February 6, 2010 Share Posted February 6, 2010 Eu am bagat 2 l.ulei Castrol SMX-75W85 cumparat de la UNIX. Este gl 4 ceea ce scrie in cartea tehnica a masinii; nu cred ca ar avea repercursiuni folosirea lui gl5 ,dar de ce sa nu folosesti ceea ce este prescris de constructor. E adevarat ca nu-i un ulei ieftin, dar nici nu prea gasesti la alte firme specificatia data. In cele din urma poti lua si de la reprezentanta uleiul adus de ei cu sigla GM. Eventual mai poti incerca si la BARDI uleiul Castrol, s-ar putea sa fie cu ceva mai ieftin. Succes ! Link to comment
niki Posted February 6, 2010 Share Posted February 6, 2010 On 2/6/2010 at 11:01 AM, markus2007 said: Pana la urma am achizitionat ulei TUTELA 75w-80 gl 5. Foarte multe persoane folosesc Total 75w80 si sunt multumite. Daca tot ai luat Tutela sa sti ca aveau si 75w85 (gl4). Am scris unde se poate gasi . 1 Link to comment
numberonebz Posted February 6, 2010 Share Posted February 6, 2010 Total 75-80 GL 4, 35 ron/l. Link to comment
markus2007 Posted February 6, 2010 Share Posted February 6, 2010 Multumesc pt. sfaturi ! Link to comment
