Mihai.Ionita Posted March 23, 2018 Share Posted March 23, 2018 Multi le-au rupt pe 2.0, nu-s primu. O sa fac, dar nu atinge supapa in piston nici asa Sent from my WAS-LX1 using Tapatalk Link to comment
florinellll Posted March 24, 2018 Share Posted March 24, 2018 . Freaca ceva pe la distributie, din ce in ce mai incet. Probabil o sa se toceasca de tot si n-o sa mai faca galagie. Am folosit tachetii si culbutorii axei de 18e si asta se aude. Poate de aceia ofta la distributie Link to comment
Mihai.Ionita Posted March 24, 2018 Share Posted March 24, 2018 Nu. Freca cureaua in capacul distribuției, cu laterala sa zic asa Sent from my WAS-LX1 using Tapatalk Link to comment
Viktor Posted March 24, 2018 Share Posted March 24, 2018 Pe mine m-ar interesa daca cele doua axe au inaltimea camelor identica. S-o rupt axa, ok, insa carui fapt se s-o datorat incidentul ? Link to comment
Mihai.Ionita Posted March 24, 2018 Share Posted March 24, 2018 0.3mm mai inalt lobul camei. Dar nu se lipeau spirele arcului, mai era destul spatiu. Stramba nu era portaxa... Nu am idee Sent from my WAS-LX1 using Tapatalk Link to comment
Dj_Dark Posted March 24, 2018 Share Posted March 24, 2018 Ca si la cielo, posibil ungere insuficienta. Eu as verifica si presiunea de ulei. Link to comment
Mihai.Ionita Posted March 25, 2018 Share Posted March 25, 2018 (edited) Poate tachet blocat, presiune de ulei avea destula, dadea mult ulei prin gaurile de ungere de pe came. Iau in calcul si asta cand desfac, o sa ii verific Sent from my WAS-LX1 using Tapatalk Edited March 25, 2018 by Mihai.Ionita Link to comment
Viktor Posted March 25, 2018 Share Posted March 25, 2018 Dati tachetii afara, curatati, gresati, remontati, noua axa, o presiune de ulei dupa cum spune Dj'u (pe masurate) si bice. Chestia cu distributia nu-i deloc sanatoasa de nu fu remediata, cunosc caz in care o busit distributia in doar citeva zile datorita faptului ca freca cureaua in cava (cu siguranta in una din protectii). Link to comment
Mihai.Ionita Posted May 12, 2018 Share Posted May 12, 2018 Am resuscitat pacientul astazi. I-am pus axa de pe c18le-ul vechi. Am desfacut prezoanele chiulasei fara sa dezlipesc garnitura, n-am mai dat chiulasa jos. A mers fara probleme, urmeaza sa vad daca e ceva cu garnitura, sper sa nu, ca m-am plictisit sa tot desfac prezoanele alea, le si schimb data urmatoare. Axa de 18E s-a rupt pentru ca era slaba acolo, axa de c18le (motorul de fabrica al masinii) e intarita in zona unde s-a rupt cea veche. Am inteles ca cineva ar putea sa o repare, sudeze, intareasca, urmeaza sa vad. Am tot cautat alta de 18E si n-am mai gasit nimic. Tachetii erau toti buni, 2 s-au dezamorsat intr-o luna, in rest erau intregi. I-am pus pe toti noi de data asta. Vreo 2 au fost mai vagabonti, s-au amorsat doar dupa ce am tinut motorul turat vreo 2 minute. Am gasit axa stock noua, dar nu mi-a placut cum era turnata si am pus-o tot pe-asta veche, care arata bine. Acel milimetru si jumatate lipsa din chiulasa se vede pe distributie, mai "la punct" de-atat nu se poate pune. De mers merge ok, fluieratul de care aminteam mai sus n-a disparut, n-am mai pus capacul distributiei, dar se vede unde freca cureaua in el. Ori atinge pompa de apa in tabla din spatele distributiei (as fi dat-o si pe-aia jos, dar fulia de la arbore e stransa cu pistol pneumatic, si n-am mai reusit sa o desfac), ori @Dj_Dark a avut dreptate si pompa de ulei canta. Mai departe tre sa-i aduc avansul undeva sa-i placa, sa curat sistemul de racire ca-i plin de ulei combinat cu antigel, sa mai inchid gap-ul bujiilor... Astea se fac saptamanile urmatoare. Back to square one, sa vedem unde gasim o axa mai grasa. Link to comment
Dj_Dark Posted May 14, 2018 Share Posted May 14, 2018 Te astept joi, intre timp sa o resuscitez si pe a mea, detalii in topicul meu 🙂 Link to comment
Mihai.Ionita Posted May 23, 2018 Share Posted May 23, 2018 Am slabit azi cureaua de distributie, era intinsa "cu ura". A mai disparut din fluieratul pe care-l facea, sta o idee mai frumos la ralanti si parca a mai gasit niste cuplu pe undeva. Urmeaza garnitura la teava care leaga ventilatia carterului inferior de cel superior. Pierde ceva ulei pe-acolo, si am gasit-o pe origine Link to comment
Mihai.Ionita Posted July 9, 2018 Share Posted July 9, 2018 M-am trezit intr-o seara ca las apa pe jos, pica de undeva de pe sub pompa de apa. Zic aia e, am traznit pompa cat am tinut cureaua intinsa. Imi iau pompa, imi iau si intinzator si curea ptr intinzator, sa nu mai am probleme. Dau distributia jos, vreau sa pun intinzatorul, nu am filete in bloc. Adica au fost candva, dar nu mai sunt. Tarozi nu aveam, si oricum sa fac filete in blocul de fonta nu mi s-a parut cea mai buna idee, asa ca am pus cureaua "veche" la loc. Pun distributia, ii dau cheie, concert de la motor. Ma apucase noaptea, asa ca am strans tot si am zis ca o dau jos in alta zi. Era joi, eu luni aveam examen. Revin luni la masina sa o fac si sa plec la Buzau: baterie moarta, uitasem o lampa pe spate aprinsa. Am lasat-o in Bucuresti, m-am intors o saptamana mai tarziu. Desfac iar distributia, freca pinionul de la distributie in tabla de protectie. Incerc s-o pun fara, nu reusesc s-o pun la semn, dupa 4 incercari pun tabla la loc, pun distributia, totul bun. Dau sa-i completez apa, pornesc motorul, las sa se incalzeasca si pun mana pe furtunul dintre radiator si termostat: o taietura de vreo 2cm. Asa am schimbat o pompa de apa degeaba, si am stat o saptamana si ceva fara masina. Apa ajungea pe fulia compresorului, pana pe fulia de accesorii, si de-acolo pe jos. In alta ordine de idei, am gasit alta axa de 18E, noua, din stoc vechi, modelul "cu crestatura" pentru delcou, in Grecia. E trimisa, trebuie sa ajunga zilele astea. Imi mai incerc o data norocul cu garnitura asta de chiulasa. Pana imi vine axa ma apuc si de interior, saptamana asta am in plan sa pun scaunele fata de Saab, si sa desfac compresorul de AC, care a reusit sa piarda tot freonul in 2 zile 2 1 Link to comment
Dj_Dark Posted July 9, 2018 Share Posted July 9, 2018 Welcome to the club 😄 o sa-ti scoata peri albi aerul vietii. Link to comment
Mihai.Ionita Posted July 10, 2018 Share Posted July 10, 2018 A ajuns si axa astazi. Are un disc excentric fix unde s-a rupt cealalta, gros de vreo 7-8mm sa zic. Camele la ochi par la fel, clar nu e ca cea pe care o am acum pe motor. Sper sa nu mai am probleme cu asta. Revin cu poze sa explic ce zic mai sus mai tarziu, cand fac rost de poze cu cea rupta Link to comment
Viktor Posted July 10, 2018 Share Posted July 10, 2018 Eh, o pompa de apa mai merge. Comparativ cu altii ce-au fost la un pas de a schimba un motor cu totul in locul a 4 bujii incandescente ... Link to comment
Mihai.Ionita Posted July 11, 2018 Share Posted July 11, 2018 Avea si cealalta axa discul excentric de care vorbesc. Axa de c18le/c20ne nu il are. Tot citesc pe net de "break-in" la axa noua, si tot gasesc metode diferite. Voi cum stiti ca se face? Link to comment
Dj_Dark Posted July 14, 2018 Share Posted July 14, 2018 Ce aia bre? break ce? Zi pe romaneste 🙂 Discul ala excentric o fi contrabalansor la came pentru echilibrare dinamica. Link to comment
Mihai.Ionita Posted July 14, 2018 Share Posted July 14, 2018 Din ce citeam pe net si prin manuale de service, cand se monteaza o axa si culbutori noi, se recomanda sa tii motorul la x turatie, y minute, cu z ulei si apoi sa schimbi uleiul. Vreau niste pareri pe tema asta. Am gasit variatii de la "nu e nevoie" la "am distrus axa cu came" si nu stiu ce sa mai cred Link to comment
Dj_Dark Posted July 14, 2018 Share Posted July 14, 2018 Am vazut si eu pe net ineptii. Eu personal sunt pentru folosirea vaselinei aleia mai groase daca e disponibila dar l-as tine la relanti. Nu am schimbat niciodata axa cu came noua, insa nu as tine un motor proaspat facut turat la x turatii, does not feel right, indiferent de ce se schimba. Probabil ei acolo il tin asa pentru presiune de ulei sporita, altfel nu imi explic. Pe romaneste, unge-o bine cu ulei si las-o la relanti in rodaj, asta e sfatul meu. 1 Link to comment
nt98adu Posted July 15, 2018 Share Posted July 15, 2018 Probabil o tin turata sa se amorseze tachetii, altfel nu vad logica. Ai montat axa noua si o lasi mai usor in primii 500 km timp in care urmaresti eventualele zgomote suspecte. Alte precautii nu-si au rostul. 1 Link to comment
Viktor Posted July 15, 2018 Share Posted July 15, 2018 (edited) Mi-s de aceiasi parere, a nu se ridica motorul in ture. Ai se sustin ca trebue turat au atasat si o teorie clara pe o logica sanatoasa ? La mintea mea, odata cu turatiile in ideea de a creste presiunea de ulei (sa zicem) simultat creste si frictiunea urmata si de o crestere rapida a temperaturii ce in cazul unor piese noi si "uscate" nu prea da cu plus, dimpotriva. Personal, as merge pe porniri repetate cu pret de citeva secunde pina ce isi ia ulei din plin. Referitor la schimbul de ulei, il gasesc cumva la libera alegere. Pentru linistea ta si totodata pentru sanatatea motorului, schimba-l. Daca un motor dupa RC alearga ~ 500km si nu crapa, de ce ar fi problema de la o amarita de axa ca nu scade la jumatate da-o-n durere ... Eu sincer, n-as face un schimb de ulei pentru atita lucru, precum nici n-as merge pe N-spe feluri de ulei. Cel mult scurtez perioada a primului schimb de ulei dupa care revin la normal. Edited July 15, 2018 by Viktor 2 Link to comment
Mihai.Ionita Posted July 15, 2018 Share Posted July 15, 2018 O sa mai dureze putin pana ajunge in motor, culbutorii nu ii am, si raman fara asigurare rovinieta si itp in acelasi timp. Mai merg pe uleiul asta, am deja 3000 pe el, cu el o sa las motorul prima data pornit vreo ora, la ralanti, sa se aseze putin axa pe culbutori. Daca stau putin sa ma gandesc, filtrul o sa prinda eventualele particule metalice care pot aparea, chiar mai merge lasat vreo 500-1000 dupa. Tachetii au fost pusi noi, la aia nu mai umblu Link to comment
Mihai.Ionita Posted July 18, 2018 Share Posted July 18, 2018 Si s-au montat si scaunele de Saab. Cum ma asteptam, nu se potriveau la nimic. La sine nu ma asteptam, dar si ca latime e diferenta. Am pastrat sinele de espero, doar reglajul fata/spate, si am prins peste ele cadrul scaunelor de Saab. Da-i, taie, injura niturile care nu ieseau nici polizate, o distractie. Poza de mai jos e facuta aseara, cand am ajuns acasa. Par foarte murdare in poza aia, nu prea le avantajeaza, in realitate nu-s asa. O sa mai fac cateva poze azi si la "ingineria" pe care am facut-o sa le prind, si la scaune in sine. Bancheta n-am pus-o inca, urmeaza sa o pun 1 Link to comment
Geo_ZGA Posted July 18, 2018 Share Posted July 18, 2018 Hai ca de nu s-au montat pe Cielo/Espero toate neamurile de scaune :)) Si de n-spe feluri de Opel, si de Saab, si de Mazda, si de Alfa... Link to comment
