Alinutz
Everything posted by Alinutz
  1. Cam ceva de genul : " Connect the scanner of the block of management of the engine to socket OBD-II of your car and fix the screen of the scanner so that it could be seen from a place of the driver. At occurrence of any malfunctions the scanner will publish a sound signal and to inform number of an error code. The scanner constantly in real time reads out data from the block of management as the engine and analyzes them. If any parameter will fall outside the limits norm - the scanner will publish a sound signal. he scanner constantly in real time reads out data from the block of management as the engine and analyzes them. If any parameter will fall outside the limits norm - the scanner will publish a sound signal. The scanner in a condition constantly to analyze more than 800 parameters. All codes of mistakes which it shows - the same, as well as on scanners of official dealers. For example, code P0112 means that the temperature of an admission is too small, while P0113 means, that the temperature of an admission is too high. The list of codes of mistakes can be looked on site Hyundai Webtech. Diagnostics of work of the engine will be much easier, if you will use this scanner as you already will have on hands an information, what not so with your engine still before you will get on service. The main advantage of use of this scanner that you have an opportunity constantly to be well informed about a condition of work of the engine and to catch even those rare problems which usually cease to prove when you visit car-care center. Fans of tuning also will find this device very useful as the scanner will help to define what of cylinders do not work, what gauge works with deviations from norm why control lamp Check Engine, etc. burns This scanner is usually used by end users to find out problems with the engine. It cannot replace OEM scanners, but can be used as the inexpensive diagnostic tool. In a usual mode when with the engine all is normal, the scanner shows a pressure in an onboard network of your car. THE PREVENTION: Before the order, please be convinced, that the socket for connection OBD-II on your car (usually is in the block of safety locks or near to it) has the same form, as well as the socket of the scanner shown on a photo. (http://translation2.paralink.com/)
  2. M-a bagat in boala ce am gasit aici http://www.koravto.com/catalog/car_accesso...D=151#nav_start
  3. Ce baghete sunt ? Unde le-ai gasit ? Cat te-au costat ... Baga detalii
  4. A vazut cineva stopuri clare pt Lacetti ? Sau mai bine, stie unde s-ar putea gasii ?!
  5. Aoleu guru ... n-ai vrea sa stii cum chinuie biata buburuza, alexino aista, mare si rau
  6. OFf mai alexino mai ... numa' cu gandul la "amortizoare" stai )
  7. Hmmm .. cam devreme ... doar ce a trecut ultima intalnire ... mai astept pana sa-mi anunt (sau nu) prezenta
  8. Mda ... am avut cativa absenti care ar merita warn pe motiv de absenta nemotivata si neanuntata ... guru ... si emil ...
  9. Ah ... ma speriasem ca ratasem vreo ocazie sa ma dau cu masinuta pe zapada #
  10. ... a mai fost zapada ? din cate stiu eu nu ...
  11. Mai e un pic si se face joi ... care se anunta ? ia sa va vad, doua degete sus
  12. Dar numai ca unii dintre noi sunt mai tradatori ... a se vedea cazul Alexino si lexu' si cam trag chiulul. Propun o testare scurta pt absentii de data trecuta
  13. Hmm ... eu cred ca o sa vin in proportie de 85% !
  14. Douz, faza e ca eu am luat pe un drum EUROPEAN ... spre Pitesti, dupa ce treci de padurea Saru, prin una din serpentinele acelea ... scuze de offtopic
  15. Eu am pus scut mare ca addon, la dealer, si am reusit sa-l infund urat de tot, inclusiv suporti motorului, pe care se sprijina. Era ceva picat pe drum, pe care nu am mai avut timp sa-l ocolesc, si l-am luat intre roti. Daca nu aveam scutul, cred ca nu mai era baia de ulei si in plus am mai indoit si acele "margini rasfrante in jos ale traversei suspensiei" spate ... asa ca ... cele 6 mil date pe scut si-au facut datoria !
  16. Satori ... am repetat de mai multe ori testul (parca 3 ori) si la 9 imi scoate intre 7.1-7.3 cam asa ... mers super linistit, super constant ... edit ... da(m)n zice ca a scos 6 ... vreau si eu 6
  17. da(m)n esti sigur de masuratoare ? Cum ai facut masuratoarea ?! Eu n-am reusit sa scot sub 7 nici la 80/90 ... mi se pare cam ireal
  18. Cum e ... s-a tinut ? Daca da ... mi-ati dus dorul ?
  19. Eu nu vin sunt racit copt, si numa' de stat pe afara prin frig nu-mi arde poate data viitoare ...
  20. Se pare ca asta este ... nu ne mai vedem anul asta (cel putin nu organizat si stabilit dinainte) si ... hai sa va urez toate cele bune in noul an, sa se rastoarne carul cu bani la voi la usa (recunosc, am luat-o si eu de undeva ) si numai bine alaturi de cei dragi !
  21. Eu de data asta nu o sa vin ... am vorbit cu lexu' si a zis ca el ar venii daca ar fi cazul ... (nu-i mai merge calculatorul, si eu sunt intermediarul lui )
  22. Pt maine se mai tine ceva ? pt ca eu nu cred ca voi mai venii maine
