dan_m
Hands Free Bluetooth
Ma gandeam ca "puterea" asta ( depinde cum pui accentul :D ) consuma asa , oricum, de nebuna, sau doar cand se afla in legatura cu un alt dispozitiv bluetooth ?
Adica putere asta activeaza si dezactiveaza Bluetooth?
Se pare ca da... Nici conexiunea simultana a hands-free-ului cu alte telefoane nu merge.
:scarpin: cat ai dat, bre, pe laseru' ala, bh-900?
320 RON parca a fost.
Eu l-am primit free of charge. N-as da atatia bani pe el.
Guru, las-o on. Sau, daca vrei, fa teste, dar eu cred ca rezulta consum mic.
Am mers cu masina vreo 5 ore, timp in care am lasat-o pe on, si am vorbit la tel vreo 7-8 minute. Bateria s-a consumat in mod normal. In urma acestei observatii, cred ca acel consum suplimentar, care nu e de neglijat, apare doar in timpul unei convorbiri.
Eu am un Plantronics Discovery 640. A fost vreo 350 lei acum jumatate de an. Intre timp a scazut pretul, cam la jumatate
http://plantronics.com/north_america/en_US...57/prod29780004
http://plantronics.com/media/media_resourc...640_ug_en_e.pdf
E mic, e al naibii de destept, din ce am citit in manual - dar nu am testat - e printre putinele care suporta 2 device-uri SIMULTAN - Atentie ca la celelalte suporta 2 sau mai multe, dar nu simultan. Din pacate rahatul meu de telefon nu stie apelare vocala (cica nokia communicator - telefon "biznis" :wallbanger: )
USING MULTIPOINT (MORE
THAN ONE BLUETOOTH
DEVICE)
Plantronics Discovery 640 supports Multipoint technology, which permits simultaneous connections with two different Bluetooth audio devices.
TO PAIR ANOTHER BLUETOOTH DEVICE
Repeat the previous pairing steps with the
new device.
INITIATE A CALL The headset will assume
you wish to initiate a call on the device
recently used.
TO USE THE SECOND DEVICE Initiate the
call using the controls on the second device.
The second device will form the link with
the headset.
ANSWER A CALL An incoming call on either
device will ring through the headset. In
most cases, the ring tone from the device
will transfer through to the headset,
allowing the user to determine which
device is ringing. In some cases, however,
the headset will apply a ring tone to the
incoming call. In either case, the user may
be able to determine which device is ringing
through the distinct ring tone.
To answer the call, press the Call
Control Button.
TO ANSWER A CALL ON ONE DEVICE
WHILE TALKING ON THE OTHER There is
no capability for placing one call on hold
while answering another. Therefore, to
answer the second call, the fi rst call must
be terminated.
Terminate the fi rst call by pressing the call
control button once.
Wait for the beep and then answer the
second call by pressing the Call Control
Button again. If you choose not to answer
the second call, and you have voice mail
on the second device, the call will go to
voice mail.
Edited by ALiCE
