dadu1976 Posted October 12, 2007 (edited) Pai hai sa facem o statistica si sa rugam membrii sa ne arate: tip motor abs sau non abs nr km probleme mil ps incep eu tip motor- 1.2 abs sau non abs- fara abs nr km-11000 probleme mil -nu Edited October 13, 2007 by Satori Share this post Link to post
Immortal Posted October 12, 2007 (edited) 1.4 16V, ABS, 23mii km. LE: no "mil", haha ) Edited October 12, 2007 by Immortal Share this post Link to post
starsteel Posted October 12, 2007 tip motor - 1.4 16 valve abs sau non abs - abs nr km -3.300 probleme - nu P.S. mil ? Share this post Link to post
MCojo Posted October 12, 2007 Sondajul e incomplet... 1,4 8V ABS 36k km no mil De fapt la motorul asta nu se va auzi in veci de mil aprins... ) Share this post Link to post
Razv Posted October 12, 2007 (edited) @starsteel - beculetu' care arata ca motorul are o "problema" 1.4 16v 6.000 km abs da no mil Ai gresit poll'ul . Trebuia prima intrebare "motorizare" si a 2'a "mil aprins " da/nu Edited October 12, 2007 by Razv Share this post Link to post
paul_marines Posted October 12, 2007 Sondajul e incomplet...1,4 8V ABS 36k km no mil De fapt la motorul asta nu se va auzi in veci de mil aprins... ) Idem cu precizarea ca la mine indica 84 000 km Share this post Link to post
Satori Posted October 13, 2007 Am modificat pollul ca sa pot vota si eu No mil. Share this post Link to post
Abram Burel Posted October 13, 2007 (edited) Trebuia sa mai umbli 1,4/16V - 43K - No Statistica era mai relevanta daca se facea pe tipuri de motoare. In plus sunt prea multe game de kilometraj, ceea ce o sa imprastie rezultatele. Si inca, ABS-ul este irelevant, chiar daca se dezbate in ultima vreme un caz ciudat! Edited October 13, 2007 by Abram Burel Share this post Link to post
Satori Posted October 13, 2007 Pai umbla in continuare, are peste 50k, vede subturare si talpa (s-ar putea zice ca numai extremele le vede) si tot nu are MIL aprins. De acord cu ABS, mai ales ca sunt 2 feluri. Share this post Link to post
dadu1976 Posted October 13, 2007 daca considerati ca e utila modificarea, chiar va rog sa interveniti Share this post Link to post
Satori Posted October 13, 2007 Am modificat deja, dar acum imi dau seama ca nu era neaparat necesara, intra in peste 40kkm. Share this post Link to post
rm.popa Posted October 13, 2007 (edited) 1.2 cu ABS: Mil present and solved (umblat la supape la vreo 8.000 km). Acum are 12.000 - no problem. Edited October 13, 2007 by rm.popa Share this post Link to post
zapacitu Posted October 13, 2007 Tip motor- 1.2 abs sau non abs- fara abs nr km-16000 probleme mil -nu Share this post Link to post
Lucian M Posted October 13, 2007 1,4 16v - 12500km - no mil (vede talpa la greu). Share this post Link to post
hawkeye Posted October 13, 2007 1.4 16v abs - vandut la 32.000km, fara mil 1.4 16v abs - 19.000km, fara mil. 2.0 24v abs - 27.000km, fara mil. Nu am votat pentru ca nu mi s-a aprins. Pana la urma, ce relevanta are ABS-ul? Share this post Link to post
EM!L Posted October 13, 2007 In legatura cu aprinderea MIL, cred ca e irelevant daca masina este sau nu dotata cu ABS (indiferent de tipul lui). Share this post Link to post
zack Posted October 14, 2007 imi pare rau de offtopic dar...cred ca ABS-ul este folosit drept "nivel de echipare" Share this post Link to post
Abram Burel Posted October 14, 2007 Ca veni vorba de off-topic... hai sa stabilim ce vrem sa obtinem de la topicul asta si sa refacem poll-ul... Altfel ne cam aflam in treaba. Incep eu Intentia a fost sa se faca o statistica a aprinderii MIL. Asta inseamna ca referinta e: "toate cazurile". Daca prindem toate masinile, ar fi interesant sa vedem pe tipuri de motoare, deci pana aici toate bune, numai ca s-a bagat si ABS, care nu prea are treaba cu broblema (chiar daca ai lui senzori de pe roti inlocuiesc punctul G sau senzorul G, nu-mi aduc aminte). Deci avem 1,2/8v, 1,4/8v si 1,4/16v. Buuun. Acum, daca vrem sa comparam ceva, atunci votul trebuie dat pe fiecare motor in parte. Asta inseamna ca tipul de motor nu e o lista de vot, ci o categorisire a celorlalte liste. Altfel se amesteca treaba. Atunci ce votam? Pai, cand s-a aprins MIL-ul. Bine, bine, dar chiar cand: prima oara, a doua oara sau cat a stat aprins? Judecand dupa cele discutate in topicul cu MIL, nu prea exista reguli, dar pare totusi ca un MIL tratat cand a inceput sa faca pe nebunul a fost in cele din urma rezolvat in urmatoarele cateva mii de Km (cel mult). Cumva rezulta ca numarul de Km pe care-i are masina acum e relevand doar pentru cei carora nu li s-a aprins MIL-ul (ca sa se laude si ei ), in timp ce ceilalti trebuie sa voteze Km la care a avut loc incidentul. In ceea ce priveste gamele, parca aparea mai des in primii 10K, deci ar trebui mai fin aici si pe urma mai grosier. In plus, poate ar fi interesant de stiut cam cum s-a rezolvat chestia, asa in general. Prin urmare, polul (dupa AB ) ar trebui sa fie asa: 1. Am Kalos/Aveo cu motor de 1.2/8v si s-a aprins MIL: intre 0 si 5.000 Km intre 5.000 si 10.000 Km intre 10.000 si 20.000 Km peste 20.000 Km niciodata 2. Am Kalos/Aveo cu motor de 1.4/8v si s-a aprins MIL: idem 3. Am Kalos/Aveo cu motor de 1.4/16v si s-a aprins MIL: idem 4. problema s-a rezolvat: doar cu talpa cu chimicale si talpa cu interventii la motor (rectificat scaune, schimbat supape) altfel inca nu s-a rezolvat (doar daca persista dupa mai multe tentative de remediere) n-a fost cazul E bine sau v-am ametit de tot? Share this post Link to post
rm.popa Posted October 14, 2007 E bine, e bine. Pe mine m-a cam ameţit varianta actuală, aşa că să-i dăm bice(pşi)! Noroc că sunt cu "mil on" şi am putut vota... Share this post Link to post
geof Posted October 14, 2007 Motor 1.4 16V Kilometraj: 39000 ABS: Da Mil- NU. Si o intrebare poate pricepem mai bine: Eu cu cine votez? Share this post Link to post
