dumos Posted January 25, 2006 Poate e vrun fanatic si pe la noi sa si le ia primu > The Future of Car Suspensions While there have been enhancements and improvements to both springs and shock absorbers, the basic design of car suspensions has not undergone a significant evolution over the years. But all of that's about to change with the introduction of a brand-new suspension design conceived by Bose -- the same Bose known for its innovations in acoustic technologies. Some experts are going so far as to say that the Bose suspension is the biggest advance in automobile suspensions since the introduction of an all-independent design. How does it work? The Bose system uses a linear electromagnetic motor (LEM) at each wheel in lieu of a conventional shock-and-spring setup. Amplifiers provide electricity to the motors in such a way that their power is regenerated with each compression of the system. The main benefit of the motors is that they are not limited by the inertia inherent in conventional fluid-based dampers. As a result, an LEM can extend and compress at a much greater speed, virtually eliminating all vibrations in the passenger cabin. The wheel's motion can be so finely controlled that the body of the car remains level regardless of what's happening at the wheel. The LEM can also counteract the body motion of the car while accelerating, braking and cornering, giving the driver a greater sense of control. Unfortunately, this paradigm-shifting suspension won't be available until 2009, when it will be offered on one or more high-end luxury cars. Until then, drivers will have to rely on the tried-and-true suspension methods that have smoothed out bumpy rides for centuries. For more information http://www.edmunds.com/insideline/do/Featu...rticleId=103183 Share this post Link to post
mikken Posted January 25, 2006 Mda...auzisem si eu mai demult de treaba asta, smechere rau amortizoare. Si daca ne gandim la ce a facut Bose in domeniul audio...cred ca si amortizoarele astea o sa fiu un succes pe piata. Bine, nu pentru noi muritorii de rand, poate o sa-si puna Jiji pe Maybach ca sa fie el miezu miejilor, in rest...pentru noi o sa ramana doar un vis. Pe site nu au zis nimic de un pret estimativ...probabil sa nu se sperie lumea Share this post Link to post
aztec Posted January 25, 2006 mda.. de 2 ani nimic nou..din pacate adevarul e ca sunt uimitoare, cine vrea sa vada filmuletul pus acolo cu un demo.. http://automobilemag.com/news/0410_bose/ film demo http://automobilemag.com/news/0410_bose_bumps.wmv Share this post Link to post
CT_ZDB Posted January 28, 2006 Super bune rezultatele.. din ce se observa in filmuletul ala... va dati seama ce ar sinsemna sistemul asta de suspentii pentru Tara Romaneasca, plina de gropi? Nu ar mai deranja pe nimeni gropile si nu ar mai fi astupate.. ) O sa mai treaca mult timp pana o sa se monteze asa ceva pe masini. Share this post Link to post
roberth Posted February 11, 2006 (edited) zuper ! ... chiar sunt curios cat vor costa ... dar pana atunci vom fi in UE si gropile vor fi interzise in Bucuresti... Tnx man, acum pot sa visez frumos ! Edited February 11, 2006 by roberth Share this post Link to post
