Apocalips Posted April 5, 2008 (edited) Sau poate are un dispozitiv de a prinde aparatul de masina si se plimba in cerc 15 secunde cu aceeasi viteza ca prea e TOATA masina clara Later edit: Am facut un test Edited April 5, 2008 by Apocalips Share this post Link to post
Tommy Posted April 6, 2008 Mda.. am citit ca exista filtre ce modifica traseul razelor de lumina, se pare ca asa ceva se foloseste pentru ca efectul asta sa se scoata usor. Am incercat cateva teste si nu prea mi-a iesit, singura lumanarie am obtinut-o marind timpul de expunere, dar la viteza mai mare nu iese grozav. Nimic notabil de postat. Share this post Link to post
Apocalips Posted April 7, 2008 (edited) Mda.. am citit ca exista filtre ce modifica traseul razelor de lumina, se pare ca asa ceva se foloseste pentru ca efectul asta sa se scoata usor. Cred ca la ND-uri te referi: http://www.f64.ro/catzero.php?id=444&o...id_criteriu=506 Vreau sa-mi iau si eu unu din asta ca merge fain la peisaje cu nori, cascade, masinia si cam orice se misca si lasa urma faina singura lumanarie am obtinut-o marind timpul de expunere, dar la viteza mai mare nu iese grozav. I like the car to be going around 60 mph while standing back from the road a few hundred feet. Set the camera on shutter priority and select a shutter speed between 1/125th and 1/200th of a second. If you've got auto-focus, turn it on. If your auto-focus is too slow and won't let you take the picture, select manual focus and pre-focus on a rock or distinguishing mark on the road near where you want to take the picture. Pan with the car and squeeze the shutter as the car passes that point. This will take a while to perfect, so don't get discouraged. Oh, make sure you've got a full tank of gas. Plan on taking 50 to 100 shots to get one really good one. (Don't try this with a film camera! You'll go broke.) Folosind viteze mai mari, scazi timpul de expunere si nu mai trebuie filtru sa nu-ti iasa poza supraexpusa (eventual unu de polarizare circulara care scade putin din lumina) Dar tu ai incerat panning simplu cu subiectul in miscare de la stanga la dreapta sau ai vrut s prinzi momentu ala in curba? Edited April 7, 2008 by Apocalips Share this post Link to post
Tommy Posted April 7, 2008 De la stanga la dreapta, nu prea am gasit curbe pe aici si sa pot si sta in ele Pai am scazut timpul de expunere .. dar la 100kmh+ nu mai merge 1/60 sau 1/30 ca iese miscata si masina.. La 1/200 sec iesea prea clar, insa mai e ceva, nu am gasit o zona unde sa am un background apropiat. Mi-a iesit una cat de cat la viteza mai mica, dar e un pic miscata. Plus ca era soare prea mare si a trebuit sa inchid diafragma la 11-14. Ia uite aici: http://digital-photography-school.com/blog...oving-subjects/ daca astea sunt scoase fara filtru eu imi dau foc la valiza Share this post Link to post
VAXXi Posted April 8, 2008 Cum se cheama/face efectul asta? E vorba de punctuletele alea. Share this post Link to post
VFX Posted April 9, 2008 E un filtru de PS (probabil) si ar trebui sa se numeasca, ceva de genul, Newspaper/Halftone Pattern(Filters/Sketch) aplicat pe un layer dublat si dupa dat un tip de overlay care-ti convine... Share this post Link to post
Cristaky Posted April 9, 2008 Cu permisiunea voastra, pun un link si eu. Fotografiile sunt realizate de un prieten foarte bun, cu care colaborez si eu. http://www.flickr.com/photos/overlordmephi...57604314317361/ Share this post Link to post
Tommy Posted April 9, 2008 Nu am sa inteleg niciodata pornirea de a poza mizerii si saracie.. Retoric.. asta e tot ce poate vedea ochiul nostru? Share this post Link to post
VFX Posted April 9, 2008 Tommy, asta "se vinde" cel mai repede + ca are impact mai mare decat un peisaj or smtf... Cam toti pe care-i stiu si au inceput sa faca fotografie (ca hobby)...cu asta incepeau...homeless-i, ruine, etc... Share this post Link to post
Tommy Posted April 9, 2008 Orice cap sec poate poza cu sete un amarat al soartei, dar magia.. eh.. magia e altceva. Share this post Link to post
Lucian M Posted April 9, 2008 (edited) Am si eu o intrebare: se da o imagine fundal, deja incarcata in photo impact 11, peste care trebuie atasata o alta imagine (un fundal cu flori peste care se asaza doua persoane). As vrea sa pot aseza unde vreau eu (adica central) oamenii si sa le fac un contur fade (adica ceva neregulat, pierdut). Stiu ca e tarziu- insa sunt in stare sa rod monitorul- numai sa ma culc mai repede, ca de juma de ora trudesc la poza asta. Ma ajuta cineva? Am vazut la cineva cum se face, insa pot sa ma arunc in cap- ca tot nu retin ce comenzi a dat ala. Multam anticipat! Am instalat si photoshop cs2. A mers pana la urma. Avand in vedere ora si faptul ca e prima "realizare", eu unul sunt aproape multumit. Urmatoarele vor iesi mai bine (sper). Edited April 10, 2008 by Lucian M Share this post Link to post
el cid Posted April 9, 2008 Da-i pe tutoriale photoshop , ca vad ca-l ai, si gasesti sigur asa ceva.Si daca la ora asta mi esti pe aici "> In alta ordine de idei, referitor la postul cu masina: Asa ceva se face mai usor cu photoshop-ul decat sa pierzi timp pana iese doar din aparat. Si dupa parerea mea este "ciupita" cu un program pc. Share this post Link to post
SorinG Posted April 10, 2008 Pt. Lucian M: vezi ca Photoshopu face si niste rame frumoase pt. genul asta de poze... Share this post Link to post
Cristaky Posted April 10, 2008 Tommy - nu inteleg de ce te ataci asa...ti-a bagat cineva mana in buzunar pt a plati acele fotografii? Nu le-am postat doar pt mesajul transmis (cu toate ca o fotografie care nu transmite nici un mesaj = 0) ci si pentru calitatea fotografiei (dpdv tehnic, intensitatea culorilor, etc). Ma uimeste in continuare placerea ta de a fi mereu "gigi-contra".... Share this post Link to post
Zmeul cel rau Posted April 10, 2008 A comentat pozele. Despre asta e topicul. Share this post Link to post
Satori Posted April 10, 2008 Nu am sa inteleg niciodata pornirea de a poza mizerii si saracie..Retoric.. asta e tot ce poate vedea ochiul nostru? Unde unii vad probleme, altii vad solutii. Share this post Link to post
Cristaky Posted April 10, 2008 "Orice cap sec poate poza cu sete un amarat al soartei" Da, foarte tare comentariu. Constructiv. Dar daca despre asta e topicul... Share this post Link to post
Satori Posted April 10, 2008 Orice cap sec poate poza cu sete un amarat al soartei, dar magia.. eh.. magia e altceva. Exagerezi crunt. O fotografie trebuie sa spuna o poveste. Fiecare om are povestile lui preferate. Share this post Link to post
Zmeul cel rau Posted April 10, 2008 "Orice cap sec poate poza cu sete un amarat al soartei" Da, foarte tare comentariu. Constructiv. Dar daca despre asta e topicul... Autorul acestui comentariu, exasperat fiind de imaginile sumbre pe care media romaneasca le repeta cu infrigurare, atrage atentia ca imaginile banale nu fac parte din arta. Cotidianul nu poate deveni special si, cu cat se aduc mai multe contraexemple, cu atat mai mult astfel de fotografie isi pierde din valoare, ramanand doar o copie palida. Share this post Link to post
Cristaky Posted April 10, 2008 Mi-am justificat actiunea prin postul #1926. Mai departe nu facem decat sa poluam topicul. Share this post Link to post
zapacitu Posted April 10, 2008 Prima mea interventie pe topicul asta. Sper sa va placa, e o incercare timida facuta cu un aparat destul de vechi. Share this post Link to post
Tommy Posted April 10, 2008 D-lor, arta este felul frumos de a spune un adevar. Nu este o definitie data de mine, nu sunt mai bun ca altii si nici macar un gigi contra. Cristaki, developeaza cateva pagini pe reverse si vei gasi si cuvinte de lauda scrise de mine, si discutii si incercari de a aduce cate ceva dupa slaba mea pregatire, dar cu cele mai bune intentii, asa ca tine-ti aproape antipatiile ieftine si replicile refuzate de idee. Comentariile mele nu se vor a fi cu obsesivitate constructive, considerand utopica si naiva o asemenea intentie, ci se multumesc uneori a fi anti-distructive. Share this post Link to post
Apocalips Posted April 11, 2008 Mi-am mai luat o jucarea Mi-am facut comanda la un blitz de studio care m-a costat 3.4 mil cu tot cu transport. L-am luat pe bucati ca daca il luam intreg ma costa 3.9 mil. Am luat asa: Stativ de 1.9m - 90 lei Blitz 45w + cablu sincron - 110 lei Umbrela alba - 63 lei Cap stativ care tine umbrela si in care se infileteaza blitz-ul - 45 lei Cap declansare sincron care se pune pe aparat 16 lei Mi-a venit ieri pe la 14 si nu am apucat sa experimentez cu el asa ca rezultate prea interesante inca nu am pentru ca trebuie sa ma mai documentez. Pe mine am incercat putin dar e greu asa ca dupa cateva cadre am renuntat ca incercarile se desfasurau lent cu drumuri ba la scaun ba la aparat sa vad cum a iesit poza.. dar azi am incercat putin pe pisica. Nu e fioroasa dar casca Mai trebuie sa iau vre-o 2 sau 3 metri patrati de panza neagra sa am si eu un fundal normal ca acum m-am chinui cu aceeasi panza golosita la spartu baloanelor care e un petec de 75cm patrati cred. Share this post Link to post
VFX Posted April 11, 2008 Foarte misto...aia fioroasa...pardon, cand casca... Bun pretul...de unde l-ai luat? Share this post Link to post
Apocalips Posted April 11, 2008 De pe F64 le-am luat. Stativ http://www.f64.ro/det.php?id=332&pid=5560 Suport biltz/umbrela http://www.f64.ro/det.php?id=341&pid=3042 Umbrela http://www.f64.ro/det.php?id=333&pid=925 Blitz http://www.f64.ro/det.php?id=248&pid=921 Cap de sincronizare http://www.f64.ro/det.php?id=166&pid=4396 Share this post Link to post
