VAXXi Posted December 11, 2009 Lotus Omnivore Engine – 10% Better Fuel Economy than Current Leading Gasoline Engines Traducere in romana cu Google Translate The Omnivore is a two-stroke direct-injected engine designed to take advantage of the latest in electronic engine management and run on just about any liquid fuel (hence the name). In the time since the initial announcement, the boffins at Lotus Engineering have been exercising their creation on the dyno stand to evaluate its performance. The single-cylinder engine uses an air-assisted direct injection system. A movable "puck" in the top of the cylinder head allows the compression ratio to be varied. si restul articolului pe Autoblog. Share this post Link to post
EM!L Posted December 12, 2009 Ce "compression ratio" are la "10% load"... 50:1 Share this post Link to post
root Posted December 12, 2009 Partea cea mai interesanta e ca rata de compresie e variabila. Are 50:1 la sarcini mici si scade odata cu cresterea sarcinii. Share this post Link to post
smailmiami Posted December 12, 2009 Da cat o costa un motor d-asta fata de unul normal ? Share this post Link to post
TLGTLC Posted March 24, 2010 Nu stiu de ce am impresia dar tehnologia nu e noua! Share this post Link to post
