egerjoco Posted April 12, 2006 Am cumparat o Tico fab. 1998 . Afost tot in ordine am mers 280 KM cu 12.2 litru benzine asta consumul mixt dar problema este ca acum consume 5.3-5.8 ce este cu motor sau ce are? daca puteti ajutati va rog Share this post Link to post
bobu Posted April 12, 2006 nu cred ca ti-a consumat mixt doar 4,357%. motorul nu are nimic, consumul de 5,3-5,8 este un consum bun (mixt). Share this post Link to post
egerjoco Posted April 12, 2006 (edited) nu cred ca ti-a consumat mixt doar 4,357%.motorul nu are nimic, consumul de 5,3-5,8 este un consum bun (mixt). da am inteles dar daca merg in afara oras cat trebuie sa consume 4.5 sau 5? dar acum motorul consume 5.3 in afara oras! Si nu are putere!! merge numai 100 -120 KM/H Cu 2 Persoane Edited April 12, 2006 by egerjoco Share this post Link to post
AAdorjan Posted April 12, 2006 (edited) Da' cu cat ar trebui sa mearga? Daca consuma 5.3 cu o viteza de croaziera 120 eu zic sa fi multumit. Edited April 12, 2006 by AAdorjan Share this post Link to post
egerjoco Posted April 12, 2006 (edited) SI Ce este Asta? Cum trebuie sa functioneaza? Edited April 12, 2006 by egerjoco Share this post Link to post
mike.omega Posted April 12, 2006 (edited) Eu in locul tau as fi fericit cu consumul asta Am impresia ca aia e electrovala care face ceva dar nu stiu exact ce Vezi te rog si urmatoarele discutii: http://www.daewooclub.ro/forum/index.php?s...&hl=consum+tico http://www.daewooclub.ro/forum/index.php?s...&hl=consum+tico http://www.daewooclub.ro/forum/index.php?showtopic=8765&hl= http://www.daewooclub.ro/forum/index.php?showtopic=4330&hl= http://www.daewooclub.ro/forum/index.php?showtopic=6318&hl= http://www.daewooclub.ro/forum/index.php?showtopic=7259&hl= http://www.daewooclub.ro/forum/index.php?showtopic=2481&hl= Si cred ca mai sunt Edited April 12, 2006 by mike.omega Share this post Link to post
egerjoco Posted April 12, 2006 Am Tico fabricat 1998 motor cu carburator (nu cu injectie) ce fel de benzin trebuie 95 cu plumb sau fara plumb??????? Share this post Link to post
mike.omega Posted April 12, 2006 Si?! Are si o electrovalva(pe 3 cai chiar) care nu stiu sigur daca e cea din poza ta, ca nu ma pricep la mecanica dar ca idee Benzina trebuie sa fie de 95, nu conteaza cu sau fara Pb Share this post Link to post
egerjoco Posted April 12, 2006 Eu am folosit Premium95 Cu plumb si daca vrea sa schimb la Premium95 faraplumb nu conteaza pentru Tico??? Share this post Link to post
dreaQ Posted April 12, 2006 Baga linistit fara plumb. Eu am trecut pe benzina fara plumb. La un moment dat am schimbat bujiile care e bine sa fie altfel "reglate". Dar ca idee poti baga fara plumb far agrija. Share this post Link to post
adostar Posted April 12, 2006 da poti baga linistit fara plumb...dar vezi ca se consuma mai repede. Share this post Link to post
Leutzu Posted April 13, 2006 Eu de aproape 2 ani bag fara plumb..consumul e la fel, parca chiar mai mic decat cu Pb. Consumul variaza tocma de la bujii...daca ai relate pt pB normal ca haleste mai mult cand bagi fara Pb. Share this post Link to post
Alezz Posted April 13, 2006 (edited) In ziua de azi nu mai exista benzina cu plumb...are doar niste aditivi de inlocuire ai Pb. Edited April 13, 2006 by Alezz Share this post Link to post
SORAN Posted April 13, 2006 Valva aia te ajuta la pornire nu are legatura cu consumul teoretic. Consuma bine daca e asa cum zici tu! E indicat sa pui benzina cu inlocuitori de Pb daca nu este modelul de Tico euro 2. Oricum ca idee Tico cu injectie nu are nimeni ca nu prea exista Share this post Link to post
tolin Posted April 13, 2006 Vezi bujiile si distanta dintre electrozi. Aceasta difera in functie de benzina utilizata. Daca folosesti benzina cu Pb (inlocuitor), atunci sa ai 0,7-0,8mm, altfel 1,0-1,1 mm. Si schimba filtrul de aer mai des, daca vrei consum mic. Vezi si cum ai clapeta de la priza de aer, pe iarna sau pe vara ? Share this post Link to post
egerjoco Posted April 14, 2006 Vezi c. Aceasta difera in functie de benzina utilizata. Daca folosesti benzina cu Pb (inlocuitor), atunci sa ai 0,7-0,8mm, altfel 1,0-1,1 mm. Si schimba filtrul de aer mai des, daca vrei consum mic. Vezi si cum ai clapeta de la priza de aer, pe iarna sau pe vara ? clapeta de la priza de aer, e pe iarna acum pentru ca la zi avem temperatura 10-12 C si pe manual scri ca Vara incepe 15-2* C si am lasat clapeta la Iarne(winter) si folosesc benzin normal cu plumb si am reglat bujiile si distanta dintre electrozi intre 1.0-1.1!!!!!! Acum trebuie sa fac reglare distanta dintre electrozi 0.7-0.8 ????????????? Multumesc! Share this post Link to post
dreaQ Posted April 14, 2006 Daca "te dai" pe fara plumb lasa la 1-1,1 mm. In ultima instanta trebuie un reglaj la carburator... Share this post Link to post
