Daewoo & Chevrolet Forum: Piese Matiz - Daewoo & Chevrolet Forum
Joi seara, in parcare Cronicarul Obi pe Hotnews!
  • (16 Pages)
  • 1
  • 2
  • 3
  • 4
  • 5
  • Last »
  • You cannot start a new topic
  • You cannot reply to this topic
Piese Matiz Preturi si de unde Rate Topic: ****- 2 Votes
#41 User is offline   mortymer
  • Forumist
  • Group: Membru
  • Din:bucuresti
  • Auto:daewoo / kia
  • Model:matiz e/ac / cee'd city 1.4
  • An:2004 / 31.12.2008
Posted 21 August 2006 - 14:03
Brat fata matiz - 154 lei doua bucati (de la autodaewoo.ro) - ca i-am stresat cu unul pana mi-au trimis daoua
Buson rezervor ( piesa de origine ) - 11 lei de la magazinul de la pasajul muncii( pe stanga, iesirea spre iancului).
This post has been edited by Mircea: 21 August 2006 - 14:27
0
#42 User is offline   smailmiami
  • Forumist
  • Group: Membru
  • Din:Craiova
  • Auto:Daewoo
  • Model:Leganza
  • An:2003
  • Nr. Inmatr.:DJ-10-DKL
Posted 28 August 2006 - 21:38
Sa pun si eu niste preturi in RON.
culbutor - 28.
ax culbutori - 31.
ax came - 25.
curea distributie - 33.
pinion distributie - 19.
set garnituri (inclusiv semeringuri si garnitura chiulasa)- 62.
set segmenti ST - 61.
telescop fata - 88.
disc frana - 82(incredibil, dar aveau si cu 32, dar n-am avut curaj sa cumpar).
This post has been edited by smailmiami: 28 August 2006 - 21:43
0
#43 User is offline   dxr
  • Forumist
  • Group: Membru
  • Din:Bucuresti | Berceni
  • Auto:Daewoo | Renault | Renault
  • Model:Matiz E | Symbol | Twingo Sport
  • An:2005 | 2005 | 2003
  • Nr. Inmatr.:... / ...
Posted 23 September 2006 - 19:03
Proiectoare originale Matiz 1.550.000 lei/buc de la King Campione. Filtru de aer Matiz 210.000 lei de la aceeasi sursa. Tot aici am vazut ca aveau la vanzare stopuri Cielo tip Nexia, adica in doua culori (rosu + alb), in loc de trei culori (rosu + alb + portocaliu)
This post has been edited by dxr: 23 September 2006 - 19:05
0
#44 User is offline   CristiP
  • Forumist
  • Group: Membru
  • Din:Bucuresti
  • Auto:Daewoo
  • Model:Matiz SE Power
  • An:Aprilie 2004/ Il am din octombrie 2005
  • Nr. Inmatr.:OT-07-BLK
Posted 21 October 2006 - 09:38
Mi s-a ars si mie proiectorul de pe stanga, unde gasesc sa cumpar si eu?
Si c-am cat ar costa?
0
#45 User is offline   dxr
  • Forumist
  • Group: Membru
Posted 22 October 2006 - 10:00
Presupun ca ti s-a ars becul proiectorului din stanga. Bec H3 se gaseste la orice benzinarie, magazin de piese auto sau prin hipermarketuri.
0
#46 User is offline   CristiP
  • Forumist
  • Group: Membru
  • Din:Bucuresti
  • Auto:Daewoo
Posted 23 October 2006 - 08:46
Multumesc,
o sa cumpar si o sa-l schimb la service,am aruncat asa o privire si e cam complicat pentru mine, oricum trebuie sa fac revizia.
0
#47 User is offline   Gizmo
  • Forumist
  • Group: Membru
  • Din:Craiova
  • Auto:Daewoo
  • Model:Matiz E
  • An:2005
Posted 29 November 2006 - 18:55
View PostMircea, on Jul 30 2006, 08:47 PM, said:
Piesa 2. Capacul 5 se foloseste pentru matijii fara proiectoare, ca sa astupe gaurile alea.
Indiferent de Matiz piesa 5 nu exista montata din fabrica ca sa astupe gaurile de la proiectoare.
Numai bine.
View PostObi_wan_Kenobi, on May 24 2005, 06:23 AM, said:
Dragalasilor, stie careva pe unde as putea gasi aparatori de cauciuc pentru pedalele care este? Saru' mina!
Am dat pe cautare, da' n-am gasit, sa traiti!!!
Pt. postul #7:
Aparatori de cauciuc pt. pedale: cele de Tico se potrivesc ca doua picaturi de apa asa ca...poti sa ceri linistit si de alea.
Numai bine.
0
#48 User is offline   CristiP
  • Forumist
  • Group: Membru
  • Din:Bucuresti
  • Auto:Daewoo
Posted 06 December 2006 - 12:03
Vreau sa-mi schimb capacele, cu acelasi model, am intrebat la magazinul de pe Str.Virtutii langa Pod Ciurel si costa 75 RON, gasesc mai iefitin in alta parte?
Attached File(s)
  • Attached File  capac.JPG (279.37K)
0
#49 User is offline   laurentziu83
  • Câine Rau
  • Group: Membru
  • Din:Galați
  • Auto:.
  • Model:.
  • An:.
  • Nr. Inmatr.:.
Posted 06 December 2006 - 13:04
Valva PCV: 11 lei, Galati, magazinul de pe Traian de langa piata, cel cu piese si pentru Oltcit.
0
#50 User is offline   smailmiami
  • Forumist
  • Group: Membru
  • Din:Craiova
  • Auto:Daewoo
  • Model:Leganza
  • An:2003
Posted 06 December 2006 - 22:12
Cam pe-aici se-nvart preturile pentru capace ... Ce mi s-a parut interesant este ca am vazut la un magazin unde vindeau si la bucata.
0
#51 User is offline   acidifiant
  • Forumist
  • Group: Membru
  • Din:Bucuresti
  • Auto:Daewoo
  • Model:Matiz
  • An:2001
Posted 08 December 2006 - 10:55
salutare.. unde gasesc suport de introdus centura fatza(cu buton rosu ) unul cu contact electric si celalalt fara contact electric??
0
#52 User is offline   laurentziu83
  • Câine Rau
  • Group: Membru
  • Din:Galați
  • Auto:.
  • Model:.
  • An:.
  • Nr. Inmatr.:.
Posted 09 December 2006 - 20:02
Galati: Zetec (in Tiglina, vis-a-vis de dioda)
Ulei Castrol Softec Plus 5W30 42 lei litrul (schimb ulei gratuit)
Filtru ulei Purolator 10 lei/buc
Solutie curatat motor engine flush (nu mai stiu exact producatorul) 10 lei/buc
Frontal (tot p-acolo)
Filtru aer Purolator 26 lei/buc
Buji Ngk BPR5EY-11 GAP 1 MM 14 lei/buc
Le dau eu codul la baieti, se apuca sa caute in baza de date, ma intreaba ala "pentru ford, nu?", "nu dom'le, pentru Matiz", moment in care mai multi au inceput sa se uite chioras la mine "uite si la ala ce pune pe kkt-ul ala de masina" dovada ca romanii inca nu au educatie.
In fine, le-am luat si le-am montat si parca am alta masina. :lavolan:
Ramane sa gasesc ulei de cutie, preferabil Total, antigel, placute si lichid de frana, si apoi sa merg in service sa schimb distributia si lichidu de frana. Antigelul pot sa-l schimb si singur, da i-as baga si o curatare de instalatie.
0
#53 User is offline   zalmoxis
  • Membru Fondator
  • Group: Gold Member
  • Din:Bucuresti
  • Auto:Daewoo
  • Model:Matiz
Posted 13 December 2006 - 08:44
Un brat de stergator ptr. hayon stie cineva de unde pot cumpara!?!....(mi l-au vandalizat pe Mati :uff: !)
0
#54 User is offline   NFS
  • Membru Fondator
  • Group: Super Moderatori
  • Din:Bucuresti
  • Auto:Hyundai
  • Model:Getz
  • An:2007
Posted 13 December 2006 - 09:42
Vezi magazinul de pe Vacaresti, suna-i, eu am fost multumit de ei.
http://www.gmclub.ro/forum/index.php?s=&am...ost&p=10781
0
#55 User is offline   zalmoxis
  • Membru Fondator
  • Din:Bucuresti
  • Auto:Daewoo
  • Model:Matiz
Posted 13 December 2006 - 10:56
Multam Serge...I'll check them !!!
0
#56 User is offline   zapacitu
  • Forumist
  • Group: Membru
  • Din:Montreal
  • Auto:Crysler
  • Model:99' Intrepid
  • An:1999
  • Nr. Inmatr.:Q60 AJX
Posted 14 December 2006 - 21:14
Apropo de magazinul de pe Vacaresti.
Sa va povestesc ce-am patit ieri seara.
Ma duc la ei sa cumpar un set de fise de bujii pentru Matiz.Intru, intreb daca sint si cit costa.Un nene de dupa tejghea se uita in calculator, zice ca sint si ca pretul e de 65 RON.M-am gindit ca sint cam scumpe, dar aveam nevoie si nu mai aveam timp sa umblu si zic bine, asta e, le iau.Atunci, nenea ma intreaba daca vreau factura pe firma sau ceva.Eu zic ca nu, nu vreau nici o factura, el se apleaca, face repede niste calcule pe un calculator din ala mic de birou si-mi zice:
Ok, atunci tre sa platiti 50RON.Zic hopaaa, bun.Am dat banu, am luat fisele si am intins-o.
Nu stiu care a fost faza, dar e de retinut.Poate au preturi diferite pentru persoane fizice si persoane juridice, desi nu vad de ce.Sau a facut si omu o spaga. :)
This post has been edited by zapacitu: 14 December 2006 - 21:18
0
#57 User is offline   andreib
  • Diasporic
  • Din:Iasi
  • Auto:Daewoo, Fiat, Reno
  • Model:Nubira II, GP, Kangoo
  • An:2005, 2007, 2005
Posted 14 December 2006 - 22:32
Poate au preturi diferite la negru :) .
0
#58 User is offline   smailmiami
  • Forumist
  • Group: Membru
  • Din:Craiova
  • Auto:Daewoo
  • Model:Leganza
  • An:2003
Posted 14 December 2006 - 22:59
Avea fise fara factura la care nu trebuia sa mai plateasca TVA si impozit.
Ex: Luam pretul de angro de aprox 40 RON (cam asta e pretul maxim la care sunt aduse fise de calitate la noi in tara). TVA platit = aprox 8 RON. TVa incasat la 65 RON este de aprox 15 RON. => diferenta de platit la stat de 7 RON. Impozit de profit = (65 - 35)*16/100 = 4 RON. Rezulta un total de max 11 RON. Eu asa as calcula. Dar el a facut mai repede si a scazut (gresit) rapid 20% din pretul final si i-a dat 50RON.
0
#59 User is offline   laurentziu83
  • Câine Rau
  • Group: Membru
  • Din:Galați
  • Auto:.
  • Model:.
  • An:.
  • Nr. Inmatr.:.
Posted 19 December 2006 - 21:30
Stergatoare Champion pentru Matiz: 38 de lei ambele: unul 13 lei si celalalt 25 de lei.
Alta viata fata de lamelele cumparate cu 3 lei bucata acum 2 ani si mesterite la cutter. Totusi pana si alea stergeau mai bine decat Valeo-urile de la Clio. :((
0
#60 User is offline   catelu23
  • Forumist
  • Group: Membru
  • Din:giurgiu
  • Auto:daewo
  • Model:matiz
  • An:2005
Posted 24 December 2006 - 18:00
salut as dori sa stiu si eu de unde pot sa cumpar si eu un stop de dreapta second si o carcasa de filtru de aer , si polita din spate sau mai simplu de unde pot sa gasesc piese second hand de matiz in Bucuresti
0
Share this topic:
  • (16 Pages)
  • 1
  • 2
  • 3
  • 4
  • 5
  • Last »
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
