Vand Difuzoare Auto Jbl Gto 6528 16.5Cm 60W Rms
ches
Vand 2 boxe auto provenite de la Epica, le-am avut cativa ani pe fata, arata ca noi, nu sunt abuzate, in 90% unitatea audio este folosita la 25% din volum, iar peste 60% nu am trecut niciodata.
Boxele se aud foarte bine pe melodii cu bass si inalte, insa sunt sub cele stock in zona de medii (de regula ascult rock si pop), de aceea m-am intors la sistemul original.
Difurile de bass si tweeterele au filtre pasive, iar twiterele au atenuare reglabila 0db, -3dB. NU am mai gasit grilele, se dau asa cum arata in poze.
Specificatii complete:
Low-Q-Woofer-Design: The motor design of new GTO woofers offers significantly reduced distortion levels at high volume levels. The low-Q design allows for soft roll-off and better low-frequency extension than on competing speakers.
Plus One© cones
My-Ti tweeter
Selector switch for high frequency volume: In the GTO 6528, the tweeter level can be lowered with a switch even after it has been mounted, enabling making adjustments to the individual taste and music respectively.
Unipivot Tweeter: The GTO 6528 has a tweeter, mounted in a 15ø angle to the front, swivelling in a 360ø. This enables you to adjust the radiation exactly to the listening position: the spacial sound and the frequency response even outside of the radiation central axis (e.g. doors) improves.
Built-in crossover network for tweeters: The new GTO 6528 speakers has an integrated high and low pass filter The advantage: the smooth transition between woofer and tweeter improves the middle performance considerably. Technical Details: JBL GTO 6528
165 mm 2-way speakers
Frequency range: 50 Hz - 21 kHz
Efficiency: 92 dB
Impedance: 2 Ohms
Continuous output power (RMS): 60 Watt
Peak load capacity 180 Watt
Installation depth: 59mm
Pretul de vanzare este de 120 lei.
Contact: paul_vali82@hotmail.com sau PM, va dau nr de telefon acolo ca sa evit spamul
post-4287-0-25209100-1524465538_thumb.jpg post-4287-0-04246900-1524465542_thumb.jpg
