Leutzu Posted October 25, 2007 Vand un cd-player Kenwood KD-2021S. Are urmatoarele specificatii: Maximum output power ...4 5 W x 4 Output power (DIN 45324, +B=14.4V) ...28 W x 4 Tone action Bass :................................................. ...100 Hz ±10 dB Middle : ... ...1 kHz ±10 dB Treble : ... ...10 kHz ±10 dB Preout level / Load (during disc play) ...1800 mV/10 k½ Preout impedance (during disc play) ...² 600 ½ FM tuner section Frequency range (50 kHz space) ...87.5 MHz – 108.0 MHz Usable sensitivity (S/N = 26dB) ...0.7 μV/75 ½ Quieting Sensitivity (S/N = 46dB) ...1.6 μV/75 ½ Frequency response (±3 dB) ...30 Hz – 15 kHz Signal to Noise ratio (MONO)............................................ ..65 dB Selectivity (DIN) (±400 kHz) ...³ 80 dB Stereo separation (1 kHz) ... ..35 dB MW tuner section Frequency range (9 kHz space) ...531 kHz – 1611 kHz Usable sensitivity (S/N = 20dB) ...25 μV LW tuner section Frequency range... .153 kHz – 281 kHz Usable sensitivity (S/N = 20dB) ...45 μV CD player section Laser diode ... ..GaAlAs (l=780 nm) Digital filter (D/A)......................................8 Times Over Sampling D/A Converter ... ...1 Bit Spindle speed... ..500 – 200 rpm (CLV) Wow & Flutter ...Below Measurable Limit Frequency response (±1 dB) ...10 Hz – 20 kHz Total harmonic distortion (1 kHz) ...0.01 % Signal to Noise ratio (1 kHz) ...96 dB Dynamic range ... ...93 dB Channel separation... ...85 dB Pret 170lei negociabil. Bonus: mufa adaptoare ISO (pentru masinile care nu au din fabrica acea mufa de conectare). Playerul a fost pe Suzuki pe mi-am montat pe el acum playerul care era pe tico. Functioneaza impecabil si receptia posturilor de radio este mult mai buna decat la Blaupunkt San Diego MP35 (cel pe care l-am montat acum). Share this post Link to post
