gurugee Posted July 5, 2007 (edited) Dear All, my leganza does only 3 KM per liter, this is very bad, and I am having Bad fuel smell in my silencer. is there any thing that i can do, One nice forum told me to change CO sensor, but right after that my Check Engine came. So i correct it, but still its same. i saw some Vacuum hoses are just open on my engine. So if some one send me some close pictures, so that i can correct it vacuum system. My ideal shows me 900-1000RPMs is it ok? this is Manual 2000CC DoHC Engine 1999 Brand. Please find my car pics. i marked the faulty places Download My Car pics - Enginee & vacuum System http://rapidshare.com/files/39010574/Leganza_sri_Lanka.zip Please help me. ("> Tkx Edited July 5, 2007 by gurugee Share this post Link to post
lauamd Posted July 5, 2007 Where are the pictures ? I cannot see them. your car was subjected to an analysys with a engine scanner ? We need more information. "> Share this post Link to post
Englishman Posted July 5, 2007 ...and some pictures, eventually... the link you gave us is faulty... Share this post Link to post
Adi_Iacob Posted July 6, 2007 (edited) The link is not faulty here you go those pictures it is an archive with 22 pictures, and i think master Ovi can handle it... Edited July 6, 2007 by Adi_Iacob Share this post Link to post
gurugee Posted July 6, 2007 Hi Guys, this is great, please find those pics and help me, I reset battary too. but nothing happen. please master Ovi Help me. what can i do to get a good fuel usage. now its 3 KM per liter = 12KM per galoon Prasadperera@hotmail.com Share this post Link to post
Zmeul cel rau Posted July 6, 2007 Have you checked if your gas tank has a leak? Or maybe some tube? Your consumtion is way too bad to be caused only by a faulty sensor. It is too big also for driving only in the first gear. Share this post Link to post
gurugee Posted July 6, 2007 Hi i do not drive on first gear, but i do not know how to check sensor, and Gas tank? i check to reach Tank thru back side wher spear wheel, but its all closed. cant sea the tank. Please advice. Tkx Share this post Link to post
Zmeul cel rau Posted July 6, 2007 You should check for gas under the car. As for the tank, it is under the rear seats. You have to raise them to get to the tank. It's not the case here though. Share this post Link to post
ovi_jer Posted July 6, 2007 After all the vacuum hoses are ok is necessary an ECM reset and an ajusting of the injection potentiometer on the gas analyser. Share this post Link to post
gurugee Posted July 18, 2007 Hi ovi_jer, You do not know how much value those pics to me with your guide lines, its a great help. THNAKS A LOT!!! i change whole hoses as your guide, now it increase fuel use by 1.5 KM, well its not bad as i had very less fuel consumption (3KM per Liter). after all these now my RPM gone down to 1000-900 RPM. But how can i reset ECM and ajust the injection potentiometer? please advice me. awaiting for your reply Tkx you people are very nice. Keep it up!! Share this post Link to post
EM!L Posted July 18, 2007 Read here: http://www.daewooclub.ro/forum/index.php?s...st&p=117585 how to reset your Ecm! Good luck! "> Share this post Link to post
gurugee Posted August 8, 2007 hi guys, i did the scaner but No errors. and they remove and clean my IAC and fixed and now my Idle is ok. but still my check engine light is on. what i should do next. scanner said no errors found. please help. Share this post Link to post
Mircea Posted August 9, 2007 If check engine is on, errors must be read by scaner! Share this post Link to post
gurugee Posted August 10, 2007 Hi guys, i reset the ECU but still the same what i notice is when i race the accelarator, my CHK engine light goes off and when a idle mode it agains pop up. any suggestions?? Share this post Link to post
gurugee Posted August 10, 2007 hi Mircea, what is TPS senzor? where is it locate i am not a good technicale person sorry. can you please show me a pic or tell me wher is it? . please tell me how can I set it? Thank you. Share this post Link to post
Mircea Posted August 10, 2007 Is on the throtle axle, on opposite the throtle cable. If you loose the two screws that fix the TPS sensor, try rotate it conterclock wise, fix the screws back and check if the check engine is on after that Share this post Link to post
