Search the Community
Showing results for tags 'JBL GTO 6528'.
  • Search By Tags
  • Search By Author
  • FORUM DAEWOO
    • DAEWOO - Tico și Matiz
  • FORUM CHEVROLET
  • Toate modelele
    • Diverse
    • Legislație și asigurări
    • Mașina mea
    • Utile
    • Bursa
  • Parteneri media
    • Auto.ro
    • 0-100.ro
  • Alte discuții
    • Cafenea
    • Călătorii
    • Întâlniri
    • Sporturi cu motor
    • Despre forum
    • English corner
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Din
Auto
Model
An
Nr. Inmatr.
Found 1 result
  1. Vand 2 boxe auto provenite de la Epica, le-am avut cativa ani pe fata, arata ca noi, nu sunt abuzate, in 90% unitatea audio este folosita la 25% din volum, iar peste 60% nu am trecut niciodata. Boxele se aud foarte bine pe melodii cu bass si inalte, insa sunt sub cele stock in zona de medii (de regula ascult rock si pop), de aceea m-am intors la sistemul original. Difurile de bass si tweeterele au filtre pasive, iar twiterele au atenuare reglabila 0db, -3dB. NU am mai gasit grilele, se dau asa cum arata in poze. Specificatii complete: Low-Q-Woofer-Design: The motor design of new GTO woofers offers significantly reduced distortion levels at high volume levels. The low-Q design allows for soft roll-off and better low-frequency extension than on competing speakers. Plus One© cones My-Ti tweeter Selector switch for high frequency volume: In the GTO 6528, the tweeter level can be lowered with a switch even after it has been mounted, enabling making adjustments to the individual taste and music respectively. Unipivot Tweeter: The GTO 6528 has a tweeter, mounted in a 15ø angle to the front, swivelling in a 360ø. This enables you to adjust the radiation exactly to the listening position: the spacial sound and the frequency response even outside of the radiation central axis (e.g. doors) improves. Built-in crossover network for tweeters: The new GTO 6528 speakers has an integrated high and low pass filter The advantage: the smooth transition between woofer and tweeter improves the middle performance considerably. Technical Details: JBL GTO 6528 165 mm 2-way speakers Frequency range: 50 Hz - 21 kHz Efficiency: 92 dB Impedance: 2 Ohms Continuous output power (RMS): 60 Watt Peak load capacity 180 Watt Installation depth: 59mm Pretul de vanzare este de 120 lei. Contact: paul_vali82@hotmail.com sau PM, va dau nr de telefon acolo ca sa evit spamul
