ice-tuning Posted May 11, 2007 ICE Tuning ICE - In car entertainment LOW COST : Radio- CD MP3 Boxe Monitoare LCD DVD-uri PlayStation 2 Subwoffer Amplificatoare CAR PC GPS Car Kit-uri Si alte produse similare din gama LOW COST De asemenea facem si sonorizari Profi cu produse din gama Hertz, Focal si Audioson Contact: Y! : tpghites Skype: tpghites Tel: 0744 40 68 65 Oferta valabila din 8.05.2007 pana in 15.06.2007 , in limita stocului disponibil. Produsele sunt noi cu garantie. pret special 625 ron tva inclus Amplificator MTX XTHUNDER X502 2 canale + boxe componente 16.5 cm MTX THUNDER THS 652 specificatii amplif CEA RMS Power : 2x50W @ 4Ohm, 14,4 Volts CEA RMS Power : 2x90W @ 2Ohm, 14,4 Volts CEA RMS Power : 1x180W @ 4Ohm Bridged, 14,4 Volts X-over : High pass 12dB variable from 40 to 8kHz X-over : Low pass 24dB variable from 40 to 8kHz X-over : Band pass 12dB variable from 40 to 8kHz Minimum Impedance : 2Ohm stereo or 4Ohm bridged Frequency response : 20Hz - 20kHz ±1dB THD+N / 1W : <0,1% S/N ratio : 85dB Sensitivity : 0,2 to 5Volts Dimensions : 18,5x21,0x5,0cm specificatii boxe: RMS Power : 65W Max Power : 260W Impedance : 4 Ohm Frequency response : 66Hz - 25kHz Sensitivity : 91,0 dB/2,83v/1m Tweeter : 19mm Silk dome Tweeter Cut-out diameter : 40,6mm Tweeter mounting depth : 13,8mm Woofer diameter : 16,5cm Woofer Cut-out diameter : 142mm Woofer mounting depth : 66mm Injected polypropylene cone with aluminium finish Black rubber surround 2,5 cm Aluminium voice coil Solid Aluminium phase plug Original MTX Euro DIN basket Oversized magnet Rubber magnet cover with MTX logo Silk dome tweeter with MTX original phase plate Flush or eyeball installation options for the Tweeter 2-way 6dB/oct x-over X-over with high quality components (poly cap and air core coil) With tweeter protection High power handling High Sound Quality Including multi way useable speaker grills Including mounting material and wires Produsele sunt noi cu garantie. pret special 485 ron tva inclus Amplificator MTX XTHUNDER X502 2 canale + boxe coaxiale 13 cm MTX THUNDER THX 502 specificatii amplif CEA RMS Power : 2x50W @ 4Ohm, 14,4 Volts CEA RMS Power : 2x90W @ 2Ohm, 14,4 Volts CEA RMS Power : 1x180W @ 4Ohm Bridged, 14,4 Volts X-over : High pass 12dB variable from 40 to 8kHz X-over : Low pass 24dB variable from 40 to 8kHz X-over : Band pass 12dB variable from 40 to 8kHz Minimum Impedance : 2Ohm stereo or 4Ohm bridged Frequency response : 20Hz - 20kHz ±1dB THD+N / 1W : <0,1% S/N ratio : 85dB Sensitivity : 0,2 to 5Volts Dimensions : 18,5x21,0x5,0cm specificatii boxe: RMS Power : 55W Max Power : 220W Impedance : 4 Ohm Frequency response : 65Hz - 22kHz Sensitivity : 91,5 dB/2,83v/1m Tweeter : 13mm PEI dome Diameter : 13cm Cut-out diameter : 117mm Depth : 49mm Injected polypropylene cone with aluminium finish Black rubber surround Aluminium voice coil Tweeter with MTX original phase plate Pivoting tweeter Original MTX Euro DIN basket Oversized magnet Rubber magnet cover with MTX logo High power handling High Sound Quality Including multi way useable speaker grills Including mounting material and wire In perioada 11.05.2007 - 18.05.2007 in limita stocului disponibil Senzori de parcare cu montajul inclus: Senzori de parcare cu indicator: 105 euro cu montajul inclus Senzori de parcare cu oglinda : 120 euro cu montajul inclus Preturile sunt finale si au inclus TVA Plata se va face in lei la curs BRD al zilei respective Share this post Link to post
ice-tuning Posted May 18, 2007 Promotia pentru senzorii de parcare se prelungeste pana pe data pe 25.05.2007 Aveti mai jos cateva poze cu 2 masini la care s-au instalat senzori de parcare chiar azi Share this post Link to post
ticodriver Posted June 12, 2007 Ma intereseaza un Radio-MP3, care sa aiba USB si eventual sa fie compatibil cu display&comenzi volan Opel Corsa C. Astept oferta. Share this post Link to post
