brusli Posted October 27, 2004 Share Posted October 27, 2004 cum se scoate radio-ul din tico? doar din experienta proprie ,.....va rog Link to comment
Shenck Posted October 27, 2004 Share Posted October 27, 2004 Bruzli ma chinui de citeva ziel sa-l scot. Nu e cum se zicea NUMAI cu cleme (cel putin la TICO-ul meu). E un surub (cap cruce) pus pe sina, strapunge sina si radioul, in partea stinga. Surubul asta la mine este COMPLET inetpenit. Locul este foarte strimt, nu ai acces decit cu o mina. Daca reusesc iti spun cum am facut. Vezi ca boxele si antena nu sint prinsa pe mufe, ci pe papuci ca la prizele telefonice vechi. Link to comment
ovidiuc Posted October 27, 2004 Share Posted October 27, 2004 Bruce volan,radio,ce ii faci o vinzi pe bucati sau o imbunatatesti? Link to comment
brusli Posted October 27, 2004 Author Share Posted October 27, 2004 va rog frumos inca odata: la obiect. nu e la misto Link to comment
ovidiuc Posted October 27, 2004 Share Posted October 27, 2004 Nu a fost la misto,eram curios ce volan si CD ii montezi. Link to comment
aztec Posted October 27, 2004 Share Posted October 27, 2004 vezi daca te ajuta imaginea... si fi atent la montare... e la limita lungimea pt un cd player.. cam jeneaza mufele din spate Link to comment
brusli Posted October 27, 2004 Author Share Posted October 27, 2004 nu cum se monteaza...cum se demonteaza?????????????????? Link to comment
FLEX Posted October 27, 2004 Share Posted October 27, 2004 Drace! ... invers de cum se monteaza! 8) Link to comment
Satori Posted October 27, 2004 Share Posted October 27, 2004 desurubezi 2 dintre cele 3 suruburi si ... impingi de el. daca surubul de deasupra este montat ca in imagine, o sa ai probleme. daca nu, experimental - acum 10 minute - l-am gasit pus invers, il scoti imediat. Link to comment
brusli Posted October 27, 2004 Author Share Posted October 27, 2004 Quote vezi daca te ajuta imaginea... si fi atent la montare... e la limita lungimea pt un cd player.. cam jeneaza mufele din spate unde ai gasit poza asta? Link to comment
aztec Posted October 27, 2004 Share Posted October 27, 2004 la pagina 137 parca... din cartea daewoo tico de la ksi Link to comment
Shenck Posted October 27, 2004 Share Posted October 27, 2004 Quote desurubezi 2 dintre cele 3 suruburi si ... impingi de el. daca surubul de deasupra este montat ca in imagine, o sa ai probleme. daca nu, experimental - acum 10 minute - l-am gasit pus invers, il scoti imediat. Cred ca e suficient doar cel din stinga. Ma duc si incerc acum Link to comment
brusli Posted October 27, 2004 Author Share Posted October 27, 2004 @aztec: deci in pdf ul meu cu tico n-am asa ceva. unde gasesc cartea asta a ta de la ksi? @satori multumescpt. ajutor Link to comment
aztec Posted October 27, 2004 Share Posted October 27, 2004 :-D deabia acum am vazut ca mi-ai dat mesaj .. eu am cumparat-o anul trecut de la un targ de carte ce s-a tinut la muzeul de istorie de la reprezentantul edituri, prilej cu care am facut si un gisheft' adica am luat-o cu reducere parca cu ocazia targului .. adresa lor din carte e www.ksi.ro daca lucram saptamana asta ... poate ti-o imprumutam... dar sant liber si nu am treaba prin oras Link to comment
brusli Posted October 27, 2004 Author Share Posted October 27, 2004 joi la intilnire nu ajungi? Link to comment
Shenck Posted October 27, 2004 Share Posted October 27, 2004 K, deci am reusit partial demontarea: Ambele suruburi sint cap cruce si au floarea indreptata spre stinga. - se scoate surubul din stinga - se slabeste surubul de deasupra se trage un pic de radio si se apasa desupra (cu mina bagata pe sub bord), sint 2 cleme. Din exterior se apasa simultan pe cleme (pozitia e incomoda dedesupt si d'asta trebuei ajutor extern) se trage de radio. Am reusit sa-l scot cam 5 cm deorece ramine agatat intr-un fir foaret scurt (pus pe centrul radioului) , singurul fir care are un matz de protectei ca imbracaminte. Banuiesc ca e alimentarea. FIRUL intra direct in radio, si NU are mufe , nu se intinde etc. E un surubel mic in apropierea intrarii firului in radio , dar nu l-am scos pt ca nu cred ca il mai puneam pune inapoi. Celete fire se pot intinde ceva mai mult. Aici am abandonat.sugestii (exceptind taierea) ? Link to comment
brusli Posted October 27, 2004 Author Share Posted October 27, 2004 shenk...intr-o poza de aici se vede in spatele firului un papuc. io zic sa nu-l tai...mai cauta papucul Link to comment
Shenck Posted October 27, 2004 Share Posted October 27, 2004 NU stiu daca ala e papuc. La mie am vazut doar un cordon de protectei pus deasupra si fara papuc Celelte fire cum s-or scoate? Link to comment
Shenck Posted October 27, 2004 Share Posted October 27, 2004 fftopic: Am incercat sa trag tot site-ul ( ) s-au prins si mi-au blocat ip-ul Edit1: Merge "trecut" prin altavista babel si e si in engleza asa Link to comment
aztec Posted October 27, 2004 Share Posted October 27, 2004 :-D :-D :-D :-D saru' mana domnu'. m-am chinuit sa dau de ce scrie pe acolo de mi-a iesit parul alb.. asa tradus e mult... mult mai simplu si mai usor.. multumesc mult de traducere.. p.s. si daca reusesti sa tragi siteul... poate il pui pe undeva direct in engleza ca e de ajutor la tot forumul... Link to comment
Shenck Posted October 27, 2004 Share Posted October 27, 2004 La asta lucrez, dar sint meseriasi rusi, s-au gindit la toate. Link to comment
Leutzu Posted October 28, 2004 Share Posted October 28, 2004 dragii mei...daca nu reusiti sa desfaceti cass-ul de tico, ma ofer eu sa vi-l scot joi la int. Shenk, eu cand am scos ala al meu am fost neviot sa tai firele alea pt ca nu au nici o mufa. singura mufa fiind cea de la antena. Link to comment
Lucman Posted October 28, 2004 Share Posted October 28, 2004 Mai copii ati luat-o razna, nu se taie nimic. Eu am scos radioul acum 3 ani deci nu mai tin minte decat ca nu am taiat nimic, totul se mufeaza. Mai tin minte insa ca iti trebuie o surubelnita cap cruce scurta si exercitii de yoga. Asta ca sa te bagi pe sub bord stand calare pe scaunele din fata rabatate pe spate. :-D :-D :-D Din cate tin eu minte are 3 suruburi 2 laterale si unul in spate. Are 2 mufe mari, antena si un fir de masa pe care trebuie sa il desprinzi din surub. Link to comment
Shenck Posted October 28, 2004 Share Posted October 28, 2004 Quote am fost neviot sa tai firele alea pt ca nu au nici o mufa. singura mufa fiind cea de la antena. Firele alea sint firele de alimentare? @Luc: daca e doar de scos surubelul, mai merge pus la loc? Link to comment
Lucman Posted October 28, 2004 Share Posted October 28, 2004 merge dar trebuie sa ai o coloana foarte extensibila ca sa te bagi cu fata in sus sub bord Link to comment
