ICE Tuning
ICE - In car entertainment LOW COST :
Radio- CD MP3
Boxe
Monitoare LCD
DVD-uri
PlayStation 2
Subwoffer
Amplificatoare
CAR PC
GPS
Car Kit-uri
Si alte produse similare din gama LOW COST
De asemenea facem si sonorizari Profi cu produse din gama Hertz, Focal si Audioson
Contact:
Y! : tpghites
Skype: tpghites
Tel: 0744 40 68 65
Oferta valabila din 8.05.2007 pana in 15.06.2007 , in limita stocului disponibil.
Produsele sunt noi cu garantie. pret special 625 ron tva inclus
Amplificator MTX XTHUNDER X502 2 canale + boxe componente 16.5 cm MTX THUNDER THS 652
specificatii amplif
CEA RMS Power : 2x50W @ 4Ohm, 14,4 Volts
CEA RMS Power : 2x90W @ 2Ohm, 14,4 Volts
CEA RMS Power : 1x180W @ 4Ohm Bridged, 14,4 Volts
X-over : High pass 12dB variable from 40 to 8kHz
X-over : Low pass 24dB variable from 40 to 8kHz
X-over : Band pass 12dB variable from 40 to 8kHz
Minimum Impedance : 2Ohm stereo or 4Ohm bridged
Frequency response : 20Hz - 20kHz ±1dB
THD+N / 1W : <0,1%
S/N ratio : 85dB
Sensitivity : 0,2 to 5Volts
Dimensions : 18,5x21,0x5,0cm
specificatii boxe:
RMS Power : 65W
Max Power : 260W
Impedance : 4 Ohm
Frequency response : 66Hz - 25kHz
Sensitivity : 91,0 dB/2,83v/1m
Tweeter : 19mm Silk dome
Tweeter Cut-out diameter : 40,6mm
Tweeter mounting depth : 13,8mm
Woofer diameter : 16,5cm
Woofer Cut-out diameter : 142mm
Woofer mounting depth : 66mm
Injected polypropylene cone with aluminium finish
Black rubber surround
2,5 cm Aluminium voice coil
Solid Aluminium phase plug
Original MTX Euro DIN basket
Oversized magnet
Rubber magnet cover with MTX logo
Silk dome tweeter with MTX original phase plate
Flush or eyeball installation options for the Tweeter
2-way 6dB/oct x-over
X-over with high quality components (poly cap and air core coil)
With tweeter protection
High power handling
High Sound Quality
Including multi way useable speaker grills
Including mounting material and wires
Produsele sunt noi cu garantie. pret special 485 ron tva inclus
Amplificator MTX XTHUNDER X502 2 canale + boxe coaxiale 13 cm MTX THUNDER THX 502
specificatii amplif
THD+N / 1W : <0,1%
S/N ratio : 85dB
specificatii boxe:
RMS Power : 55W
Max Power : 220W
Impedance : 4 Ohm
Frequency response : 65Hz - 22kHz
Sensitivity : 91,5 dB/2,83v/1m
Tweeter : 13mm PEI dome
Diameter : 13cm
Cut-out diameter : 117mm
Depth : 49mm
Tweeter with MTX original phase plate
Pivoting tweeter
Oversized magnet
High power handling
High Sound Quality
In perioada 11.05.2007 - 18.05.2007 in limita stocului disponibil Senzori de parcare cu montajul inclus:
Senzori de parcare cu indicator: 105 euro cu montajul inclus
Senzori de parcare cu oglinda : 120 euro cu montajul inclus
Preturile sunt finale si au inclus TVA
Plata se va face in lei la curs BRD al zilei respective
