alex2150 Posted November 17, 2011 salut ma intereseaza pentru cielo etrieri cu discuri pe 13 si oglinzile. sal, s-au vandut sorry! Share this post Link to post
alex2150 Posted November 23, 2011 s-au vandut: farurile, capota , bara fata, aripi, radiator apa, semnalizarile, arcurile spate Share this post Link to post
alex2150 Posted January 3, 2012 update lista piese : usi fata stg+dr spate stg - 100lei buc electroventilator - 50lei proiectoare - 60lei setu ventilator aux ac - 50lei pompa servo-directie - 100lei parbriz - 100lei pompa benzina - 80lei motor 16v 37.000km - 500lei electromotor - 150lei regulator presiune benzina 8v sau 16v - 30lei jante 14" - 50lei buc jante 13"- 40lei buc caseta directie - 110lei suport baterie - 20lei compresor ac - 150lei radiator interior ac - 50lei etrieri 14 espero opel - 100lei setu tacheti 8v - 50lei tot culbutori 8v - 30lei toti conducte ac radiator caldura(incalzitor) - 70lei galeria admise 8v - 50lei delcou 16v - 70lei galerie evacuare 8v - 70lei galerie evacuare 16v - 50lei saxofon 8v - 50lei toba centrala - 60 toba inlocuitor catalizator - 30lei catalizator nexia - 150lei trapa nexia in 2xpozitii - 150lei planetara lunga 14" - 120lei planetara scurta 14" - 100lei planetara lunga 13" - 120lei planetara scurta 13" - 100lei jamba 14 compelta stg+dr(rulment+fuzeta+aparatoare) - 90lei jamba 13 completa stg(rulment+fuzeta+aparatoare) - 90lei cutie viteze 8v sau 16v - 200lei calculator 8v 75cp - 50lei calculator 16v 90cp - 50lei disc ambreiaj+placa+rulment - 80lei volanta ambreiaj - 35lei volan - 25lei coloana volan completa - 25lei grile boxe bord - 10lei buc instalatie electrica panoua sigurnate 8v sau 16v - 100lei punte spate 13" completa - 110lei lampi spate stg+dr berlina cu mici defecte - 20lei buc bara spate berlina cu armatura - 120lei usi 4x - 100lei buc comanda geamuri electrice pasageri - 20lei macara geam+motoras geam electric - 65lei buc consola climatizare fara ac - 35lei rampa injectori + supapa presiune 16v - 30lei rampa injectori + supapa presiune 8v - 30lei armatura bara spate+fagure - 35lei luneta spate berlina - 80lei grila radiator - 40lei geam oglinda stg - 20lei carcasa filtru aer - 40lei tub filtru aer - 15lei rezonator - 15lei sonda temperatura radiator apa - 15lei clapeta acceleratie 8v - 35lei clapeta acceleratie 16v - 35lei semnalizari aripi alungite - 20lei setu bobina aprindere - 50lei sonda benzina nivel - 20lei senzor vacum - 35lei cablu acceleratie - 15lei ceas bord - 20lei bazin antigel - 15lei pompa frana cu servo - 70lei pompa frana - 40lei servo frana - 35lei senzor acceleratie - 25lei supapa comanda aer (yac) - 60lei scaun pasager fata modelul ro - 50lei inchidere centralizata originala daewoo - 100lei scuturi aparatoare - 20lei buc pompa ambreiaj - 30lei cilindru ambreiaj - 30lei bazin lichid stergatoare+motoras - 25lei ansamblu stergatoare - 50lei motoras stergatoare - 35lei ventilator interior climatizare - 30lei timonerie - 30lei ceasuri bord(turometru+apa benzina+carcasa)-50lei coaja bord - 40lei torpedou - 20lei bancheta spate berlina modelul ro - 25lei bancheta spate hackback plus nexia - 25lei lampa lumina interior - 10lei maneta stergatoare - 10lei panou sigurante - 100lei bloc lumini - 20lei broasca capota - 10lei contact+cheie - 25lei cablu deschis capota cu tot cu maner - 15lei contact electric - 15lei solenoid portbagaj - 20lei fulie pompa servo - 15lei fulie arbore - 15lei pinion - 15lei axe cu came 16v - 40lei ambele pompa ulei - 40lei baie ulei - 30lei bieleta directie stg+dr - 20lei buc punte spate - 80lei fuzeta 13" - 40lei fuzete spate - 30lei buc scrumiera spate - 10lei pistonas inchidere sofer - 30lei pistonas inchidere secundar - 25lei lampi spate hackback dr (apropae noua) - 20lei consola deschidere portbagaj+rezervor - 10lei bara torsiune - 30lei bascule stg+dr - 30lei buc broaste usi - 25lei buc brate stergatoare - 20lei setu suporti portbagaj plafon - 30lei setu arcuri fata - 60lei setu arc spate - 35lei amortizoare fata - 60lei amortizoare spate - 60lei tampon motor stg+dr+centru - 20lei buc buzer - 15lei tija capota motor - 10lei cilindru frana spate - 15lei scrumiera compelta - 15lei centura stg+dr fata - 15lei buc centura stg+dr spate - 10lei buc cablu frana de mana - 25lei geamuri laterale spate berlina - 25lei buc geamuri usi stg+dr fata spate - 30lei buc geamuri usi spate mici - 25lei buc coaja spate boxe berlina - 20lei mocheta interior - 30lei fir antena lung - 10lei rama avari, stergatoare, ceata , ... - 10lei butoane: avari, temporizator stergatoare, ceata, dezaburire - 10lei buc parasolar stg+dr - 10lei tetirea scaun - 10lei plafoniera - 10lei burduf filtru aer - 10lei tub filtru aer - 10lei manere interior - 5lei buc mufa casetofon-cd europa - 10lei calculator airbag - 10lei tamburi spate - 30lei ambi tub alimentare rezervor - 10lei geamuri spate hackback - 10lei buc haion cu tot cu geam - 80lei geam haion - 30lei amortizaore haion - 20lei set oglinda interior - 10lei actuator gura umplere - 20lei releu centrala inchidere cielo espero - 10lei frana de mana cu tot cu senzor - 10lei furtun etrier - 10lei buson rezervor - 10lei buson ulei - 10lei rezistor - 10lei calxon original - 15lei usa rezervor - 10lei suport casetofon+tavita - 15lei calculator abs - 25lei aparatoare stergatoare stg+dr - 20lei partea de clapete cu vacuum pt incalzire , aer , recirculare - 25lei pompa abs nexia espero - 50lei calculator abs nexia - 25lei preturile sunt negociabile tel:0766285062 / 0735800867 Share this post Link to post
alex2150 Posted January 29, 2012 update lista piese usa stg spate - 100lei buc electroventilator - 50lei ventilator aux ac - 50lei pompa servo-directie - 100lei pompa benzina - 80lei motor 16v 37.000km - 500lei regulator presiune benzina 8v sau 16v - 30lei jante 14" - 50lei buc jante 13"- 40lei buc caseta directie - 110lei suport baterie - 20lei compresor ac - 150lei radiator interior ac - 50lei etrieri 14 espero opel - 100lei setu conducte ac radiator caldura(incalzitor) - 70lei galeria admise 8v - 40lei galerie evacuare 8v - 50lei galerie evacuare 16v - 50lei saxofon 8v - 50lei toba centrala - 60 toba inlocuitor catalizator - 30lei catalizator nexia - 150lei trapa nexia in 2xpozitii - 150lei planetara lunga 14" - 120lei planetara scurta 14" - 100lei planetara lunga 13" - 120lei planetara scurta 13" - 100lei jamba 13 completa stg(rulment+fuzeta+aparatoare) - 90lei cutie viteze 8v sau 16v - 200lei calculator 8v 75cp - 50lei disc ambreiaj+placa+rulment - 80lei volanta ambreiaj - 35lei volan - 25lei coloana volan completa - 25lei grile boxe bord - 10lei buc instalatie electrica panoua sigurnate 8v sau 16v - 100lei lampi spate stg+dr berlina cu mici defecte - 20lei buc bara spate berlina cu armatura - 120lei comanda geamuri electrice pasageri - 20lei macara geam+motoras geam electric - 65lei buc consola climatizare fara ac - 35lei rampa injectori + supapa presiune 16v - 30lei rampa injectori + supapa presiune 8v - 30lei armatura bara spate+fagure - 35lei luneta spate berlina - 80lei geam oglinda stg - 20lei carcasa filtru aer - 40lei tub filtru aer - 15lei rezonator - 15lei sonda temperatura radiator apa - 15lei clapeta acceleratie 8v - 35lei clapeta acceleratie 16v - 35lei semnalizari aripi alungite - 20lei setu bobina aprindere - 50lei sonda benzina nivel - 20lei senzor vacuum - 35lei cablu acceleratie - 15lei bazin antigel - 15lei pompa frana cu servo - 70lei pompa frana - 40lei servo frana - 35lei senzor acceleratie - 25lei supapa comanda aer (yac) - 60lei inchidere centralizata originala daewoo - 100lei scuturi aparatoare - 20lei buc pompa ambreiaj - 30lei cilindru ambreiaj - 30lei bazin lichid stergatoare+motoras - 25lei ansamblu stergatoare - 50lei motoras stergatoare - 35lei ventilator interior climatizare - 30lei timonerie - 30lei ceasuri bord(turometru+apa benzina+carcasa)-50lei coaja bord - 40lei torpedou - 20lei bancheta spate berlina modelul ro - 25lei bancheta spate hackback plus nexia - 25lei lampa lumina interior - 10lei maneta stergatoare - 10lei panou sigurante - 100lei bloc lumini - 20lei broasca capota - 10lei contact+cheie - 25lei cablu deschis capota cu tot cu maner - 15lei contact electric - 15lei solenoid portbagaj - 20lei fulie pompa servo - 15lei fulie arbore - 15lei pinion - 15lei axe cu came 16v - 40lei ambele pompa ulei - 40lei baie ulei - 30lei bieleta directie stg+dr - 20lei buc fuzeta 13" - 35lei fuzete spate - 30lei buc scrumiera spate - 10lei pistonas inchidere sofer - 30lei pistonas inchidere secundar - 25lei lampi spate hackback dr (apropae noua) - 20lei consola deschidere portbagaj+rezervor - 10lei bara torsiune - 30lei bascule stg+dr - 30lei buc broaste usi - 25lei buc brate stergatoare - 20lei setu suporti portbagaj plafon - 30lei setu arcuri fata - 60lei setu tampon motor stg+dr+centru - 20lei buc buzer - 15lei tija capota motor - 10lei cilindru frana spate - 15lei scrumiera compelta - 15lei centura stg+dr fata - 15lei buc centura stg+dr spate - 10lei buc cablu frana de mana - 25lei geamuri laterale spate berlina - 25lei buc geamuri usi stg+dr fata spate - 30lei buc geamuri usi spate mici - 25lei buc coaja spate boxe berlina - 20lei mocheta interior - 30lei fir antena lung - 10lei rama avari, stergatoare, ceata , ... - 10lei butoane: avari, temporizator stergatoare, ceata, dezaburire - 10lei buc parasolar stg+dr - 10lei tetirea scaun - 10lei plafoniera - 10lei burduf filtru aer - 10lei tub filtru aer - 10lei manere interior - 5lei buc mufa casetofon-cd europa - 10lei calculator airbag - 10lei tamburi spate - 30lei ambi tub alimentare rezervor - 10lei geamuri spate hackback - 10lei buc haion cu tot cu geam - 80lei geam haion - 30lei amortizaore haion - 20lei set oglinda interior - 10lei actuator gura umplere - 20lei releu centrala inchidere cielo espero - 10lei frana de mana cu tot cu senzor - 10lei furtun etrier - 10lei buson rezervor - 10lei buson ulei - 10lei rezistor - 10lei calxon original - 15lei usa rezervor - 10lei suport casetofon+tavita - 15lei calculator abs - 25lei aparatoare stergatoare stg+dr - 20lei partea de clapete cu vacuum pt incalzire , aer , recirculare - 25lei pompa abs nexia espero - 50lei calculator abs nexia - 25lei preturile sunt negociabile tel:0766285062 / 0735800867 Share this post Link to post
Dj_Dark Posted February 6, 2012 O jamba stanga pe 14" cu palierul de arc si rulmentul bune mai ai? Bara de torsiune de nexia de 22 cu tot cu bucsi si prinderi mai e? Motorul cu cat l-ai dat pana la urma? Share this post Link to post
alex2150 Posted February 9, 2012 (edited) update lista piese usa stg spate - 100lei buc electroventilator - 50lei ventilator aux ac - 50lei pompa servo-directie - 100lei pompa benzina - 80lei regulator presiune benzina 8v sau 16v - 30lei jante 14" - 50lei buc jante 13"- 40lei buc caseta directie - 110lei suport baterie - 20lei compresor ac - 150lei radiator interior ac - 50lei etrieri 14 espero opel - 100lei setu conducte ac radiator caldura(incalzitor) - 70lei galeria admise 8v - 40lei galerie evacuare 8v - 50lei galerie evacuare 16v - 50lei saxofon 8v - 50lei toba centrala - 60 toba inlocuitor catalizator - 30lei catalizator nexia - 150lei trapa nexia in 2xpozitii - 150lei conducte benzina tur+retur - 40lei planetara lunga 14" - 120lei planetara scurta 14" - 100lei jamba 13 completa stg(rulment+fuzeta+aparatoare) - 90lei cutie viteze 8v sau 16v - 200lei calculator 8v 75cp - 50lei disc ambreiaj+placa+rulment - 80lei volanta ambreiaj - 35lei volan - 25lei coloana volan completa - 25lei grile boxe bord - 10lei buc lampi spate stg+dr berlina cu mici defecte - 20lei buc bara spate berlina cu armatura - 120lei comanda geamuri electrice pasageri - 20lei macara geam+motoras geam electric - 65lei buc consola climatizare fara ac - 35lei rampa injectori + supapa presiune 16v - 30lei rampa injectori + supapa presiune 8v - 30lei armatura bara spate+fagure - 35lei luneta spate berlina - 80lei geam oglinda stg - 20lei carcasa filtru aer - 40lei tub filtru aer - 15lei rezonator - 15lei sonda temperatura radiator apa - 15lei clapeta acceleratie 8v - 35lei clapeta acceleratie 16v - 35lei semnalizari aripi alungite - 20lei setu bobina aprindere - 50lei sonda benzina nivel - 20lei senzor vacuum - 35lei cablu acceleratie - 15lei bazin antigel - 15lei pompa frana cu servo - 70lei pompa frana - 40lei servo frana - 35lei senzor acceleratie - 25lei supapa comanda aer (yac) - 60lei inchidere centralizata originala daewoo - 100lei scuturi aparatoare - 20lei buc pompa ambreiaj - 30lei cilindru ambreiaj - 30lei bazin lichid stergatoare+motoras - 25lei ansamblu stergatoare - 50lei motoras stergatoare - 35lei ventilator interior climatizare - 30lei timonerie - 30lei ceasuri bord(turometru+apa benzina+carcasa)-50lei coaja bord - 40lei torpedou - 20lei bancheta spate berlina modelul ro - 25lei bancheta spate hackback plus nexia - 25lei lampa lumina interior - 10lei maneta stergatoare - 10lei panou sigurante - 100lei bloc lumini - 20lei broasca capota - 10lei contact+cheie - 25lei cablu deschis capota cu tot cu maner - 15lei contact electric - 15lei solenoid portbagaj - 20lei fulie pompa servo - 15lei fulie arbore - 15lei pinion - 15lei axe cu came 16v - 40lei ambele pompa ulei - 40lei baie ulei - 30lei bieleta directie stg+dr - 20lei buc fuzeta 13" - 35lei fuzete spate - 30lei buc scrumiera spate - 10lei pistonas inchidere sofer - 30lei pistonas inchidere secundar - 25lei lampi spate hackback dr (apropae noua) - 20lei consola deschidere portbagaj+rezervor - 10lei bara torsiune - 30lei bascule stg+dr - 30lei buc broaste usi - 25lei buc brate stergatoare - 20lei setu suporti portbagaj plafon - 30lei setu arcuri fata - 60lei setu tampon motor stg+dr+centru - 20lei buc buzer - 15lei tija capota motor - 10lei cilindru frana spate - 15lei scrumiera compelta - 15lei centura stg+dr fata - 15lei buc centura stg+dr spate - 10lei buc cablu frana de mana - 25lei geamuri laterale spate berlina - 25lei buc geamuri usi stg+dr fata spate - 30lei buc geamuri usi spate mici - 25lei buc coaja spate boxe berlina - 20lei mocheta interior - 30lei fir antena lung - 10lei rama avari, stergatoare, ceata , ... - 10lei butoane: avari, temporizator stergatoare, ceata, dezaburire - 10lei buc parasolar stg+dr - 10lei tetirea scaun - 10lei plafoniera - 10lei burduf filtru aer - 10lei tub filtru aer - 10lei manere interior - 5lei buc mufa casetofon-cd europa - 10lei calculator airbag - 10lei tamburi spate - 30lei ambi tub alimentare rezervor - 10lei geamuri spate hackback - 10lei buc haion cu tot cu geam - 80lei geam haion - 30lei amortizaore haion - 20lei set oglinda interior - 10lei actuator gura umplere - 20lei releu centrala inchidere cielo espero - 10lei frana de mana cu tot cu senzor - 10lei furtun etrier - 10lei buson rezervor - 10lei buson ulei - 10lei rezistor - 10lei calxon original - 15lei usa rezervor - 10lei suport casetofon+tavita - 15lei calculator abs - 25lei aparatoare stergatoare stg+dr - 20lei partea de clapete cu vacuum pt incalzire , aer , recirculare - 25lei pompa abs nexia espero - 50lei calculator abs nexia - 25lei preturile sunt negociabile tel:0766285062 / 0735800867 Edited February 9, 2012 by alex2150 Share this post Link to post
alex2150 Posted February 18, 2012 update lista+preturi usa stg spate - 90lei buc electroventilator - 50lei ventilator aux ac - 50lei pompa servo-directie - 100lei pompa benzina - 70lei regulator presiune benzina 8v sau 16v - 30lei jante 14" - 50lei buc jante 13"- 40lei buc caseta directie - 100lei suport baterie - 20lei compresor ac - 140lei radiator interior ac - 40lei etrieri 14 espero opel - 100lei setu conducte ac galeria admise 8v - 40lei galerie evacuare 8v - 50lei galerie evacuare 16v - 50lei saxofon 8v - 50lei toba centrala - 60 toba inlocuitor catalizator - 30lei catalizator nexia - 150lei trapa nexia in 2xpozitii - 150lei conducte benzina tur+retur - 40lei planetara lunga 14" - 120lei planetara scurta 14" - 100lei jamba 13 completa stg(rulment+fuzeta+aparatoare) - 80lei cutie viteze 8v sau 16v - 180lei calculator 8v 75cp - 50lei disc ambreiaj+placa+rulment - 80lei volanta ambreiaj - 30lei volan - 20lei coloana volan completa - 25lei grile boxe bord - 10lei buc lampi spate stg+dr berlina cu mici defecte - 15lei buc bara spate berlina cu armatura - 120lei comanda geamuri electrice pasageri - 20lei macara geam+motoras geam electric - 65lei buc consola climatizare fara ac - 35lei rampa injectori + supapa presiune 16v - 25lei rampa injectori + supapa presiune 8v - 25lei armatura bara spate+fagure - 30lei luneta spate berlina - 80lei geam oglinda stg - 15lei carcasa filtru aer - 40lei tub filtru aer - 15lei rezonator - 15lei sonda temperatura radiator apa - 15lei clapeta acceleratie 8v - 35lei clapeta acceleratie 16v - 30lei semnalizari aripi alungite - 20lei setu bobina aprindere - 45lei sonda benzina nivel - 20lei senzor vacuum - 30lei cablu acceleratie - 15lei bazin antigel - 15lei pompa frana cu servo - 70lei pompa frana - 40lei servo frana - 35lei senzor acceleratie - 25lei supapa comanda aer (yac) - 50lei inchidere centralizata originala daewoo - 100lei scuturi aparatoare - 20lei buc pompa ambreiaj - 30lei cilindru ambreiaj - 30lei bazin lichid stergatoare+motoras - 25lei ansamblu stergatoare - 50lei motoras stergatoare - 35lei ventilator interior climatizare - 30lei timonerie - 30lei ceasuri bord(turometru+apa benzina+carcasa)-50lei coaja bord - 40lei torpedou - 20lei bancheta spate berlina modelul ro - 25lei bancheta spate hackback plus nexia - 25lei lampa lumina interior - 10lei maneta stergatoare - 10lei bloc lumini - 20lei broasca capota - 10lei cablu deschis capota cu tot cu maner - 15lei contact electric - 15lei solenoid portbagaj - 20lei fulie pompa servo - 15lei fulie arbore - 15lei pinion - 15lei axe cu came 16v - 40lei ambele pompa ulei - 40lei baie ulei - 30lei bieleta directie stg+dr - 20lei buc fuzeta 13" - 35lei fuzete spate - 30lei buc scrumiera spate - 10lei pistonas inchidere sofer - 30lei pistonas inchidere secundar - 25lei lampi spate hackback dr (apropae noua) - 20lei consola deschidere portbagaj+rezervor - 10lei bara torsiune - 30lei bascule stg+dr - 30lei buc broaste usi - 25lei buc brate stergatoare - 20lei setu suporti portbagaj plafon - 30lei setu arcuri fata - 60lei setu tampon motor stg+dr+centru - 20lei buc buzer - 15lei tija capota motor - 10lei cilindru frana spate - 15lei scrumiera compelta - 15lei centura stg+dr fata - 15lei buc centura stg+dr spate - 10lei buc cablu frana de mana - 25lei geamuri laterale spate berlina - 25lei buc geamuri usi stg+dr fata spate - 30lei buc geamuri usi spate mici - 25lei buc coaja spate boxe berlina - 20lei mocheta interior - 30lei fir antena lung - 10lei rama avari, stergatoare, ceata , ... - 10lei butoane: avari, temporizator stergatoare, ceata, dezaburire - 10lei buc parasolar stg+dr - 10lei tetirea scaun - 10lei plafoniera - 10lei burduf filtru aer - 10lei tub filtru aer - 10lei manere interior - 5lei buc mufa casetofon-cd europa - 10lei calculator airbag - 10lei tamburi spate - 30lei ambi tub alimentare rezervor - 10lei geamuri spate hackback - 10lei buc haion cu tot cu geam - 80lei geam haion - 30lei oglinda interior - 10lei actuator gura umplere - 20lei releu centrala inchidere cielo espero - 10lei frana de mana cu tot cu senzor - 10lei furtun etrier - 10lei buson rezervor - 10lei buson ulei - 10lei rezistor - 10lei calxon original - 15lei usa rezervor - 10lei suport casetofon+tavita - 15lei calculator abs - 25lei aparatoare stergatoare stg+dr - 20lei partea de clapete cu vacuum pt incalzire , aer , recirculare - 25lei pompa abs nexia espero - 50lei calculator abs nexia - 25lei preturile sunt negociabile tel:0766285062 / 0735800867 Share this post Link to post
alex2150 Posted March 20, 2012 se mai adauga o masina , lista piese update: far stg+dr - 100lei buc grila faruri (alba) - 40lei bara fata+fagure+armatura - 150lei capota fata - 150lei aripa stg+dr - 50le buc semnalizarea dr - 25lei proiectoare stg+dr - 25lei buc semnalizari alungite aripi - 25lei scuturi stg-dr + aripi - 20lei buc usi - 100lei macarale usi+motorase - 65lei buc fete de usi - 30lei buc radiator caldura - 70lei motor 8v - 600lei injectori 8v - 200lei set alternator - 150lei electromotor - 150lei chiuloasa echipata - 350lei axa cu came - 150lei tacheti+culbutori - 80lei delcou 8v - 100lei scaun sofer - 70lei ceasuri bord (km+turometru+apa benzina) - 100lei jamba stg+dr - 90lei discuri 13" - 100lei etrieri 13" - 100lei arcuri spate - 70lei amortizaore fata - 60lei set amortizaore spate - 60lei set tamburi - 40lei set consola ac - 50lei grila consola - 10lei chedere usi - 20lei buc electroventilator - 50lei ventilator aux ac - 50lei pompa servo-directie - 100lei pompa benzina - 70lei rezervor benzina - 50lei instalatie electrica partea fata faruri , proectoare ... - 30lei regulator presiune benzina 8v sau 16v - 30lei jante 14" - 50lei buc jante 13"- 40lei buc caseta directie - 100lei senzor aer - 30lei suport baterie - 20lei compresor ac - 140lei radiator interior ac - 40lei etrieri 14 espero opel - 100lei setu conducte ac conducte benzina tur-retur - 40lei galeria admise 8v - 40lei galerie evacuare 8v - 50lei galerie evacuare 16v - 50lei saxofon 8v - 50lei toba centrala - 60 toba inlocuitor catalizator - 30lei trapa nexia in 2xpozitii - 150lei conducte benzina tur+retur - 40lei planetara lunga 14" - 120lei planetara scurta 14" - 100lei planetare cutie automata - 100lei buc jamba 13 completa stg(rulment+fuzeta+aparatoare) - 80lei cutie viteze 8v sau 16v - 180lei cutie viteze automata - 300lei calculator 8v 75cp - 50lei disc ambreiaj+placa+rulment - 80lei volanta ambreiaj - 30lei volan - 20lei coloana volan completa - 25lei grile boxe bord - 10lei buc lampa spate stg berlina cu mici defecte - 15lei buc comanda geamuri electrice pasageri - 20lei macara geam+motoras geam electric - 65lei buc consola climatizare fara ac - 35lei rampa injectori + supapa presiune 16v - 25lei rampa injectori + supapa presiune 8v - 25lei armatura bara spate+fagure - 30lei luneta spate berlina - 80lei geam oglinda stg - 15lei carcasa filtru aer - 40lei tub filtru aer - 15lei rezonator - 15lei sonda temperatura radiator apa - 15lei clapeta acceleratie 8v - 35lei clapeta acceleratie 16v - 30lei semnalizari aripi alungite - 20lei setu bobina aprindere - 45lei sonda benzina nivel - 20lei senzor vacuum - 30lei cablu acceleratie - 15lei bazin antigel - 15lei pompa frana cu servo - 70lei pompa frana - 40lei servo frana - 35lei senzor acceleratie - 25lei supapa comanda aer (yac) - 50lei inchidere centralizata originala daewoo - 100lei scuturi aparatoare - 20lei buc pompa ambreiaj - 30lei cilindru ambreiaj - 30lei bazin lichid stergatoare+motoras - 25lei ansamblu stergatoare - 50lei motoras stergatoare - 35lei ventilator interior climatizare - 30lei timonerie - 30lei ceasuri bord(turometru+apa benzina+carcasa)-50lei coaja bord - 40lei torpedou - 20lei bancheta spate berlina modelul ro - 25lei bancheta spate hackback plus nexia - 25lei lampa lumina interior - 10lei maneta stergatoare - 10lei bloc lumini - 20lei broasca capota - 10lei cablu deschis capota cu tot cu maner - 15lei contact electric - 15lei solenoid portbagaj - 20lei actuator portbagaj - 20lei fulie pompa servo - 15lei fulie arbore - 15lei pinion - 15lei axe cu came 16v - 40lei ambele pompa ulei - 40lei baie ulei - 30lei bieleta directie stg+dr - 20lei buc fuzeta 13" - 35lei fuzete spate - 30lei buc scrumiera spate - 10lei pistonas inchidere sofer - 30lei pistonas inchidere secundar - 25lei lampi spate hackback dr (apropae noua) - 20lei consola deschidere portbagaj+rezervor - 10lei bascule stg+dr - 30lei buc broaste usi - 25lei buc brate stergatoare - 20lei setu suporti portbagaj plafon - 30lei setu arcuri fata - 60lei setu tampon motor stg+dr+centru - 20lei buc buzer - 15lei ceas - 20lei tija capota motor - 10lei cilindru frana spate - 15lei scrumiera compelta - 15lei centura stg+dr fata - 15lei buc centura stg+dr spate - 10lei buc cablu frana de mana - 25lei geamuri laterale spate berlina - 25lei buc geamuri usi stg+dr fata spate - 30lei buc geamuri usi spate mici - 25lei buc coaja spate boxe berlina - 20lei mocheta interior - 30lei fir antena lung - 10lei rama avari, stergatoare, ceata , ... - 10lei butoane: avari, temporizator stergatoare, ceata, dezaburire - 10lei buc parasolar stg+dr - 10lei tetirea scaun - 10lei plafoniera - 10lei burduf filtru aer - 10lei tub filtru aer - 10lei manere interior - 5lei buc mufa casetofon-cd europa - 10lei saboti - 30lei tub alimentare rezervor - 10lei geamuri spate hackback - 10lei buc haion cu tot cu geam - 80lei geam haion - 30lei oglinda interior - 10lei actuator gura umplere - 20lei releu centrala inchidere cielo espero - 10lei frana de mana cu tot cu senzor - 10lei furtun etrier - 10lei buson rezervor - 10lei buson ulei - 10lei rezistor - 10lei calxon original - 15lei usa rezervor - 10lei suport casetofon+tavita - 15lei partea de clapete cu vacuum pt incalzire , aer , recirculare - 25lei pompa abs nexia espero - 50lei calculator abs nexia - 25lei preturile sunt negociabile tel:0766285062 / 0735800867 Share this post Link to post
gmc78 Posted April 18, 2012 solenoid portbagaj - 20lei Salut. Sint interesat de solenoidul de la portbagaj. Mai este valabil? Trimiti prin posta? Share this post Link to post
alex2150 Posted April 18, 2012 Salut. Sint interesat de solenoidul de la portbagaj. Mai este valabil? Trimiti prin posta? da e valabil trimit si prin posta Share this post Link to post
florinrush Posted April 18, 2012 Fete de usi fata,modelul cu geamuri electrice ,in stare buna(nezghiriate,neciupite)fara butoane,ai?Pret? Share this post Link to post
YAN Posted April 21, 2012 aripa stanga fata ma intereseaza daca mai ai si ce culoare? mersi. Share this post Link to post
