anyaddress Posted September 11, 2007 what is the exact oil grade for my car motor i must used,i dont have a service manual to know,knowing that im from lebanon and our country weather is hot (35 c ) with high humidity levels (85%) also how i can test the level of the automatic transmition oil since ther is no testing tool Share this post Link to post
VAXXi Posted September 11, 2007 There you go, this is the oil table. You can use any *w50 oil. Share this post Link to post
king_3 Posted October 12, 2007 Hi, what viscosity and brand would you recommend for an espero 1.5 dohc. I'm from the philippines. Thanks! Share this post Link to post
VAXXi Posted October 12, 2007 How's the weather there ? Hot, cold, moderate ? Share this post Link to post
Alezz Posted October 12, 2007 and our country weather is hot (35 c ) with high humidity levels (85%) It's an old engine type,you can use with no problems 10W-40. Share this post Link to post
king_3 Posted October 13, 2007 How's the weather there ? Hot, cold, moderate ? thanks vaxx weather is hot to moderate Share this post Link to post
VAXXi Posted October 13, 2007 Ok, you can go with any 10w40, 10w50 or 15w50 grade oil. I don't know what oils you have on the market; around here, we'd stay away from Aral. Castrol, OMV were successfully used by our forum's members, without problems. Share this post Link to post
king_3 Posted October 13, 2007 Ok, you can go with any 10w40, 10w50 or 15w50 grade oil. I don't know what oils you have on the market; around here, we'd stay away from Aral. Castrol, OMV were successfully used by our forum's members, without problems. just got a gallon of Castrol GTX 20w50 since it's cheaper. i'm still to observe its effects on how the engine runs since i'm coming from a different brand (local) 5w40. appreciate your help Share this post Link to post
